The hot water switch. Show me how it should look to heat
SOURCE: i switched off the power to my electric rheem 142
Turn power off to water heater at breaker panel, remove cover where electrical cord is, and check behind it for thermostat, with red button in center, push it in to reset. It may have tripped for some reason when power turned back on to it. Do you have a multimeter, to test for power at heating element?
SOURCE: Instant hot water dispenser does not heat water.
I had the exact same problem. I even replaced the first unit with a second unit...because I was sure I hooked everything up correctly. Then I called their support line and and felt very stupid. They asked one question "are you plugging in the Quick&Hot into the same electrical outlet as the garbage disposal"?. I said yes..and the garbage disposal works fine (thinking that this indicates a good electrical outlet). She then said "That outlet works off of a switch so no electricity is getting to the Quick&Hot until the disposal is turned on). Gosh darn it...that made total sense. I then tested this out by plugging an extension cord into a different outlet and it worked fine. Boy...do I feel stupid. Hope this helps.
SOURCE: no hot water when heating tempreture reached
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
SOURCE: rheem electic water heater model 81v52s. switch
It may or may not... if not then check the reset...
Check out this tip...
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
heatman101
providing ther is no problem with water heater it should.
It it trips again check out thremostats on heater.
