SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
SOURCE: What kind of Jazzy select 6 power chair does my
Here's a link to Pride Mobility, maker of the Jazzy wheelchairs. This takes you to the Select 6; there's also a Select 6 Ultra. Just click on models and it will display all of their line of equipment.
SOURCE: my father has a jazzy select power chair. The spe...
You will have to take it to a mobility dealer to have it programmed
SOURCE: jazzy 1121 power chair won't charge when plug in
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
SOURCE: Jazzy 1121 power chair won't go
I find a lot of the controller Problems are caused by the cable running from the joy stick down to the controller gets caught on something or rubbed against something and one or more tiny wires inside are broken ... If I find a spot on the cable that is worn through, that's where I start .. Open up the insulation and check the tiny wires .. fine the broken one and repair it .. usually that solves the problem and saves you a couple hundred for the cable
