SOURCE: Bought a 444 Handi Rifle with a Bushnell 3200
O.K Your gun packs a good kick, but you might try to first, tap the scope with the handle of a fair sized screw driver, after each adjustment. Next do not adjust it so many clicks at the time just 3 clicks and see if she moves the point of impact. Try a few clicks and tap the main shaft of the scope kind of rap it then shoot for group, fair 2 rounds to see if it has settled down, then adjust a few, tap and fire. work slow with a older scope and try to stock up on the bullets you decide to go with and zero for them. Any other round you use do not zero, but use go old windage to pratice with.
SOURCE: i have a nikon 3x9 rifle scope. im shooting about
It will stop but don't turn to tight or cross hair will break, but You should never have to adjust that much 12 clicks should do it
SOURCE: marlin .308 with leopold scope. I've moved the
marlin rifles have a right hand twist in them,, they all shoot to the right,,,if you pack out the scope mount with a strip of old 35mm film on the right hand side of the scope body and reclamp the scope you should have the cross hair more to the right side
SOURCE: my elevation and windage adjustments aren't moving my scope
This can only be due to a "broken" scope. To be sure, you can put your gun in a vice (cushion it) and put the crosshairs on a fixed point. Without moving the gun, crank the adjustment knobs a good 10-15 clicks in one direction each, and see if the crosshairs move from where you had them pointed.
If they do not, the scope must be replaced. If they do move, perhaps you should try adjusting the scope quite a bit more between shots.
The best way to sight it in requires a helper. Fire one shot with the crosshairs on the bullseye. Then, without reloading, put the crosshairs back on the bullseye, and have a friend adjust the knobs until the crosshairs move to the ACTUAL point of impact of that shot. It is essential NOT to move the gun while doing this.
This method allows me to sight any gun in with only 2 shots (and a few for confirmation, of course). Best of luck!
SOURCE: siting in scope 2 ft hi at 25 yds no adjustment
well at 25ft you will run out of drop, its all down to how high the scope is above the barrel when its fitted to the rifle a 30-06 should be set up over 100 yds and shooting out that far it will be shooting low,,your rifle will shoot right out to 1000yds so you will get about 5ft drop out that far,,,and by the way,,,its very very dangers to discharge your rifle into a sand bag closer that 30 yds,, you may well get hit by a bit of the bullet jacket being striped off the bullet and coming back at you so done do it, right! shoot it over 100yds
however if its still shooting hight at say 50yds the only way to drop the point of aim is pack out the front of the scope mount with a strip of 35mm film slip it under the front ring (not the eye end) and sit the scope on it then do up the screws to nip it up this will lift up the front of the scope and it will shoot lower,,also if you were to put a strip under the eye end it razes the point of aim, i do this often for the members of my club on much biger rifles than 30-06's
and they dont drift or move off aim its a cheap fix, or you need a new mount?
