Is there a fix for this short of buying new phones?
SOURCE: Cannot send faxes when using cable company's digital voice modem
Fax machines must have a standard analog phone line. They won't work on a digital line and can actually be damaged if hooked up to one.
SOURCE: callers attepting to call me
Is it on all three phones that you experience this? Calls never come in to any of the units? If so then someone is happening at the phone box level. If it's one particular handset then it's a configuration issue / hardware issue with that handset.
Let me know and we can fix this, can you please confirm the make / model of the phone system?
SOURCE: Model #KX-TG4500B base unit w/
Yes you can definitely get a new base unit that will work with those handsets. I am confused by your other questions though. It sounds like you want to try another reset? Or you want to install a battery back up system so you can prevent this in the future? Also you are looking for someone in your area to repair the item, is that correct? It sounds like you had a technician come out already though?
Please clarify, just reply here and I can help
Tim
