The rear tub bearing is going. This is not a repairable fix as the bearing is molded into the plastic of the outer tub housing. (You can see the explosions on YouTube) Usually they will let go in high speed spin and do quite a bit of damage. These machines are made to last about 5 to 7 years and then be recycled. Find a Speed Queen dealer in your area and get a washer that is tested to last 25 years to a lifetime.
SOURCE: Samsung front loading washing machine won't spin out.
I have the exact same symptom with mine that is only 4 months old. I have a technician coming as soon as the part is available. The problem is the PCB control board. Samsung has corrected a known issue with the original and has manufactured a new one. This is a known issue and thus the part is hard to get. I have, however found a temporary fix. Unplug the machine for about a half an hour. I haven't figured out how long to do it exactly but when you plug it back in it should read PF for power failure. It's the equivalent of a reboot for your pc. I got about 3 days of service from the machine before it stopped spinning again. Another reboot and I'm back in business.
We had the same problem. We ordered the washer on Black Friday and just got it this past Sunday. We put laundry in and it would not spin. We got the dc code. We have been on the phone with Sears for the week. A repairman came out to look at the washer today. He couldn't find anything wrong and had to call the tech people for help. They said if the washer is in a space that is below 60 degrees it won't spin because the oil in the back of the drum is too thick when it is cold. They have to order a new board to heat the oil. We thought they were crazy. So we did our own experiment and put a heater in the basement. The washer worked! Now we are just waiting for the new board to see if that solves the problem so we don't have to heat the basement just to wash clothes. I am glad we can at least heat the basement and wash clothes until the part comes. I will post after it has a new board!
SOURCE: Sir, Drum of front loading washing machine making banging noise
Mine did that and had to have the washer re-balanced.
SOURCE: my front loading ge adora
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
SOURCE: My washing machine spin drum started making lot of noise and started vibrating a lot.
Not sure why this has happened in a top loader but if its less than a month old call the shop you purchased from , they should still be liable for repair or replacement .any older call the manufacturer for repair.
