Home Security Logo
Kathy Bechard - Forget Posted on Mar 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need help in resetting my Logenex doorbell - Home Security
Kardoc
Level 3:
Top Expert:
  • Master 7,503 Answers
  • Posted on Mar 14, 2019
Kardoc
Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2756616
Points
58323
1helpful
Heath Zenith SL-6180 Wireless Doorbell. I need to purchase a door button for a sl-6180-rx-a
https://www.homedepot.com/p/questions/Heath-Zenith-Wireless-Battery-Operated-Doorbell-Push-Button-Black-and-Satin-Nickel-SL-7303-02/100626792/2
I found this in the Questions
Q:Hello, I need a wireless doorbell button replacement for the Doorbell model: "desa sl-6180-rx-a". Please, help. Thanks byTim'May 31, 2020
1 Answer A: Hi Tim, Any of our Heath Zenith or Hampton Bay branded buttons will work with that model. You will need to put it in backwards compatible mode. Please contact our technical service team and we'd be happy to help.
byHeathCo'Jun 2, 2020
Also sold by Heath Zenith and where there Product Support is.
https://heath-zenith.com/products/wireless-push-button-sl-7797
5answers
My Honeywell plug-in doorbell won't stop ringing
If your Honeywell plug-in doorbell won't stop ringing, there are a few things you can try to troubleshoot the issue:
1. Check the batteries: If your doorbell has batteries, make sure they are properly installed and have enough power. Replace them with new ones if needed.
2. Check the ring options: Press the ring option button with the music sign and cycle through the different ring options until you find one that stops the ringing.
3. Reset the doorbell: To reset the doorbell, unplug it from the wall outlet and wait for a few minutes before plugging it back in. This will allow the doorbell to reset and may solve the issue.
4. Check the chime settings: If your doorbell has multiple chime options, make sure the one that's causing the issue is not selected. You can cycle through the chime options using the settings button.
5. Contact customer support: If none of the above steps work, contact Honeywell customer support for further assistance. They may be able to provide additional troubleshooting steps or offer a replacement if the doorbell is defective.
My MC602 system doorbell just stopped working. what can I do?
Did you reset it? If not try a reset this will usually fix the issues with those types of doorbells.
The reset option is under the face plate.
My IQ America Doorbell has "none" RF Transmission Condition and cannot hear the doorbell when LCD Display Unit put inside the house, but when it is put close to Camera Door Unit, everything works fine....
This is caused by either the distance between the doorbell and display unit being too great or the construction of your property like brick walls absorbing the radio signal. To overcome these issues you can add a WiFi booster that you can help increase the RF signal (radio Frequency). You will need to consult the instructions to allow you to setup the doorbell to booster.
Can I change the battery in the ring doorbell
Lots of help on this is available. A special screwdriver is apparently needed here is the info on that:
https://www.bing.com/shop?q=ring+doorbell+battery+change&FORM=SHOPPA&originIGUID=F4510BCC545345B48860F54C9885FB1C
Google Ring doorbell battery replacement.
2answers
We are installing the doorbell and here is how we have it set up: the 18 volts off transformer red wire going to transformer on doorbell, negative wire going to outside button, red wire from button going...
need more info. Doorbells do not need 2 xfrms. The red off 24 volt xfmr foes to door switch and returns on white. If you have 2 door switch one switch to front door label on doorbell and the 2nd goes to back door label. What is the brand and model number/ I'll try and walk you thru it.
2helpful
2answers
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
