Unplug the saw, look for the bolt in the center of the blade and also look for the arbor lock button, if there is no button on the motor, look for the jamb nut on the back side of the blade holder, if there is none you can use a block of wood under the blade for the teeth to bite into. Unscrew the bolt and it may be reverse thread! Remove the blade and the collar, put the new blade and collar on and tighten.
SOURCE: craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
SOURCE: 12 inch miter saw blade turns slowly and doesn't
There's no debris or wood jammed in the housing around the blade, is there? Try unplugging and removing the blade, to make sure some wood hasn't gotten wedged in there somewhere.
Otherwise, make sure the blade is on tight. If so, there is likely a problem with the motor itself.
If it's still under warranty, I'd contact Ridgid at this link: http://www.ridgid.com/Tools/Support/
Otherwise, they have a tools forum where you might be more likely to find someone who's experienced a similar problem.
Being reconditioned, it sounds suspect to me...
Sorry I couldn't be any more helpful...
SOURCE: 12'' Ryobi miter saw with loose blade
You may need to use lock tight on the threads. Also replace the standard washer with a lock washer if possible.
SOURCE: How do you change the
With the saw unplugged, push the spindle lock in on the motor side of the saw (a short black rod) while turning the blade by hand. The spindle lock will seat and hold the blade still so that you can use a wrench to loosen the nut that holds the blade on. Use the spindle lock again for tightening a new blade on the saw.
SOURCE: how do I remove 12" blade from from dw705 miter
loosen the guard screw, UNPLUG tool first, move the guard out of the way, there is a spindle lockon the backside of the gearcase push it and slowly turn the blade until it engages and then remove the bolt, it is a left hand thread. DO NOT disassemble the guard, just loosen bolt and move out away from blade also you need to have the head in the raised position.
