Washing Machines Logo
A
Anonymous Posted on Mar 14, 2019
I have a Daewoo machine model number DWDHQ1421 needs bearing cannot find a part
SUNILKUMARJUNEJA
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 69 Answers
  • Posted on Mar 14, 2019
SUNILKUMARJUNEJA
Expert
Level 2:
New Friend:
Greenhorn:
Answers
69
Questions
0
Helped
21307
Points
220
DAEWOO MACHINE IS NOT USED
2 Related Answers
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Dec 31, 2009
SOURCE: i need a part number for the front rightside
Check this SKF Product (Manufacturer Part Number: 94535254 )
Hope helps.
Anonymous
  • 3092 Answers
  • Posted on Jan 06, 2010
SOURCE: i need part number for the rear wheel bearings
Rear wheel bearing outer #PBR1
Rear wheel bearing inner #PBR8
you'll need two of each, same on both side's.
You will also need rear wheel seal's one on each side #15724.
These are Napa part number's and is a stocking item.
Testimonial: "thanks alot"
I have a Mini Daewoo washing machine. Recently the operating buttons have begun to not work when you press them. If I press a few more times, they eventually work. Is this a part I can replace?
You can try spraying the buttons with electrical switch cleaner. If there is a membrane behind the buttons, you will need to remove it and clean the contact that are behind.
Or you replace the panel, but it likely is part of the main control board.
Need model number in this Search Query!
https://www.google.com/search?q=Mini+Daewoo+washing+machine+parts
2helpful
Hi i have daewoo matiz 800cc can you help me by giving me the torque settings for the big end bearing caps please
You are looking for the torque settings for big end bearings and main bearings on a daewoo matiz?
Main bearings torques on a Daewoo Matiz 800cc (1999)
Stage 1: 25-30 Nm
Stage 2: 55-60 Nm
Big End Bearings…
Tenho uma maquina daewoo modelo f1042sp e no meio da lavagen da me h6 ajudeme
I have a machine Daewoo model f1042sp and in the middle of the washes me h6 Help me
http://gethuman.com/phone-number/Daewoo-Electronics
877-393-7823
Press 1, then 2.
Average Wait: 9 mins - Mon-Fri: 9am-8pm EST
Daewoo washing machine model number DWC-LD1421 what dose the fault code LE mean for this model
The washing machine or washer dryer door has been detected as open or unlocked.
  • Close the door!
  • Check the door lock switch
  • Check the door latch
  • Check PCB
Washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor
If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
1helpful
4answers
Where is daewoo's company in cairo, egypt? I have any problem with my washing machine.
I have DAEWOO Washing machine DWD F1011. Whithin few years water started leaking through the drive shaft and ball bearing damaged. I need service manual for how to change the ball bearing or is there any repairer in Heliopolis, Cairo area?
How many year the machine is guaranteed??
Thanks lot.
Panchal
5helpful
3answers
Need cam torque specs
1999 to 2002 - 2.0L DOHC
Camshaft bearing cap bolts intake and exhaust.
N.m (INCH LBS)
8 ( 71 )
2helpful
2answers
I need part number for the rear wheel bearings left and right , inner and outter for Daewoo lanos 2000 model
Daewoo rear wheel bearing parts numbers are
94535209 and 94535218....one each per side
Top Daewoo Washing Machines Experts
Paul Bade
vince
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
