My camera wont charge
1 Is the charger unit OK? Connect a voltmeter to the camera plug to test the voltage. While connected, wiggle the wire at both ends to test if it is broken. If not OK, replace charger unit.
2 Is the battery OK? Test battery voltage with voltmeter. Connect crocodile clip leads to the voltmeter probes and a good charger. (A cut paperclip can be inserted into the center connection of the charger.) Check that meter reading is positive, and then hold meter probes on the battery terminals, making sure polarity is correct! Voltage should drop immediately, and then start to slowly but steadily rise after after a few seconds. No change with a flat battery indicates battery failure. Replace battery.
3. If both charger and battery are good, then problem is with camera. There are no user serviceable parts inside the camera, and as with laptop computers, it will probably be more economical to buy a new product, and take advantage of the always cheaper prices of newer and better models.
