SOURCE: SmartParts Frame SPX7E only allows me to load 165 photos
2 answers...
To remove a picture, connect the frame to your PC via USB. you should see the frame appear as a drive, in my case,
36972 (E:)
open the drive as Explore, you can now see the pictures, and delete what you no longer want.
you can download the software from
http://www.smartpartsproducts.com/content/support/optipix/index.php
SOURCE: My dog ate my remote
In this case I dont think that you will find an original one ..what you have to do is to get from the old one (if you didn't disposed it already ) the frequency number ..usually written on the bottom under the buttons..and with that frequency ..you will be able to get an universal one that fits..
or ..write to the manufacturer 's support site ..and see if they can replace it ..but I doubt it ..the first idea is the best ..
I will go for trying a few ones at the local electronics store and see which one is fitting the frequency ...even if will not go for all the functions ..at least will allow you to open and close and change picks from the distance ..
OR >>>I just looked on ebay and I found this one ...its from a photo frame and from the same manufacturer and I bet will work like a charm ...I guaranty it ..cause all manufacturers use only one frequency for remotes cause it will not make sense to do otherwise ..
Here is the link I advice to grab it right now cause I only see one for this manufacturer..
http://cgi.ebay.com/SMARTPARTS-Infrarad-REMOTE-CONTROL-SP1000EF-Digital-/140428649169?pt=LH_DefaultDomain_2&hash=item20b23322d1
