Cycling Logo
C
Conrad Harris Posted on Mar 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2018 Iron 883. I want to replace the stock wheels with chrome spoke, black rim / hub wheels. Will Street Bob wheels fit? What are my options?
Raymond Richards
Level 3:
Master:
  • Master 407 Answers
  • Posted on Mar 13, 2019
Raymond Richards
Master
Level 3:
Master:
Answers
407
Questions
0
Helped
101110
Points
1345
Cool, Spook wheels should look way better. 2018 is very new. The dealer should have a list of options. Also, try J&P Cycles they sell aftermarket parts and have a fitment check to make sure the parts you order fit your bike. I use them all the time for my 1994 FLSTC. I just checked there website and it looks like you may have some options. Remember after entering your bike the search is in the top right of the page. https://www.jpcycles.com/?mrkgcl=444&mrkgadid=178517533&rkg_id=0&utm_source=google&utm_medium=cpc&utm_term=J+and+P_cycles&utm_campaign=Brand+-+J+and+P+Cycles&utm_content=text&adpos=1t1&creative=230501111991&device=c&matchtype=e&network=g&gclid=EAIaIQobChMIvo_Wvbr_4AIVj7bACh2wrwqxEAAYASAAEgLvGvD_BwE#
5 Related Answers
Anonymous
  • 193 Answers
  • Posted on Nov 22, 2008
SOURCE: wheel fitment options.
These wheels are interchangable. a number of bikers prefer the set up you have mentioned.
Bill
Anonymous
  • 10865 Answers
  • Posted on Apr 16, 2009
SOURCE: Will the tire size 235/40/R18 fit on my 2000 Oldsmobile Alero?
Take your Alero to any reputable tire dealer and they will assist you in hopes of selling you something. Just tell them you want an estimate and that you want to be sure you won't have a rubbing problem with this change.
terry stevens
  • 991 Answers
  • Posted on Aug 31, 2009
SOURCE: Need a Rear Wheel for 1973 Triumph Hurricane
wm2 front x 19" wm3 rear x 18"
Anonymous
  • 8546 Answers
  • Posted on Jan 19, 2010
SOURCE: Replacement spokes, Sturmey Archer 3-sp w/16 inch wheels
Local bike shop
Anonymous
  • 8546 Answers
  • Posted on Jan 31, 2011
SOURCE: i have a shimano rim
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/WH/EV-WH-R540-R-2124_v1_m56577569830608665.pdf
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/WH/EV-WH-R540-F-2123A_v1_m56577569830728612.pdf
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Wheel/ROAD/WH-7701-R540/SI-4AM0E-En_v1_m56577569830611927.pdf
http://www.parktool.com/blog/repair-help/wheel-and-rim-truing
Disregarding which side of the rim the spoke is attached to, you pull the wheel toward the side you want to move it on the flange end.
Replace the spokes on my huffy 18 speed 27 inch bicycle
building and truing wheels is a specialized skill that takes a lot of practice. Most manufacturers use robots to build the wheels to save on labor costs. To have a human build a wheel can cost more than $50 per wheel for the labor. Spokes retail for about $1-$2 a piece and include a brass nipple. Spokes also come in different gauges. Most bike shops that sell spokes usually only carry a few sizes in stainless steel.
If you are only replacing one or two spokes you can take the broken spoke to a bike shop and they can measure it and hopefully have the right size in stock to sell you a replacement. Use the right size spoke wrench for your spokes to unscrew the nipple from the broken spoke, you will then be able to remove (spokes can be very flexible and will bend a lot to get them out of the hub). Observe the adjacent spokes and the lacing pattern to re-install the spoke in the hub and thread it into the new nipple that came with the replacement spoke. Put the wheel back in the frame and use the brake pads as a reference guide to tighten and true the adjacent spoke nipples until the wheel no longer rubs on the brake pads and you are satisfied.
My personal opinion is that on a Huffy, it is faster, cheaper and easier to buy a replacement wheel from your local bike shop for $35-$45. The spokes, rims and hubs used on Huffy's are of very low quality (most don't even use stainless steel spokes) and a new replacement wheel from your local bike shop (LBS) will be ten times better than trying to fix the old original equipment, IMHO.
Alexrims dm18
The rim should not cause any problem - but you'll need different length spokes.
Rear hubs and front hubs are different widths, have different height hub flanges, and different amounts of "dish" (offset from the center of the hub body.
If your hubs and rims are in good shape; go ahead and re-use them; but you'll need help measuring or want to use a spoke calculator online for the correct length spokes.
2answers
Hi ! Bicycle Model : Trek 7.1 fx Wheel question What is the size of spokes and nipple for this model
More important than the bicycle model is the exact hub and rim models and specs.
At http://www.trekbikes.com/us/en/bikes/town/fitness/fx/7_1_fx#/us/en/model/details?url=us/en/bikes/town/fitness/fx/7_1_fx
I found this: "Alloy hubs; Bontrager 750 32-hole double-wall alloy rims"
which is STILL not specific enough to answer your question. Spokes come in measurements down to the millimeter and on the rear wheel the drive side differs from the non-drive side.
Measure them yourself or go online and look for a "spoke length calculator" then try to plug in the specifics of your wheels OR measure your spokes.
Or ask Trek...
http://www.trekbikes.com/faq/contact.php
Jul 13, 2011 • Trek 7.1 FX
1helpful
A spoke on the rear wheel has snapped off how can I repair it?
Simply buy a replacement spoke. Unscrew the dustcap on the tyre valve and deflate the tyres inner tube. Remove tyre using tyre levers(as you do to repair a puncture). Next remove the inner tube to reveal the spoke tensioners. undo the tension nut and allow the broken spoke to fall out, feed the other part of the broken spoke out of the hub. feed the replacement spoke through the hub and into the hole on the wheel rim. Now screw on the tensioning nut to the spoke.Tighten up to the same tension as the other spokes. replace inner tube and tyre, then reinflate. Viola!
Jan 30, 2011 • Cycling
1helpful
2answers
Wheel fitment options.
Bill
Top Chrome Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Chrome Cycling Expert? Answer questions, earn points and help others
