Https://www.helpowl.com/q/HoMedics/SS5075/Technical-Support/set-time-time-set-button-hourminute/1033266
Press and hold the TIME SET button (for more than 3 seconds) and press "+" and "-" to "INCREASE" (+) and "DECREASE" (-) to the hour. Press the TIME SET button again to set the minutes and use the "+" and "-" to "INCREASE" (+) and "DECREASE" (-) the minutes. Press the TIME SET button again to set the Year, Month and Day
SOURCE: homedics SS- 5000
Hey, OK so you know how when you plug the clock in it takes like 5 minutes to upload? Well wait till you have the time set the atomic thing stops flashing. Now when you get there press the button on the inside of the outside temperature thing. Not the c/f one. The red dot should flash on the front of the thing your holding. It should work after that. If not then make sure you don't have any computers or cell phones by it that messes with it. Hope this helps.
SOURCE: i am looking for the
Go to www.homedics.com to products to SS 5000 and you can download the user manual
SOURCE: I just bought Homedics SS-4500
http://media.homedics.com/IBs/SS-4500_IB.pdf
Also note if projection does not work correctly, Ken posted an elegant solution: holding down hour and minute unplug and plug back in (still holding down hour and minute). Made mine work!
SOURCE: homedics soundspa clock radio ss-4500
I had the same problem - the directions can now be found here: http://media.homedics.com/IBs/SS-4500_IB.pdf
