Before you toss forget remote try using buttons on tv itself press source leve you device you want to watch on then go through av /av/1 hdmi /so on using chanal up down to move or some are volume ok if your using red yellow white cords make sure they are in AV in port fist good luck i am shaw its not broken .
SOURCE: green tint
LCD projectors can have a green tint for a fiew reasons. Either the signal processor is out which can cause all sorts of funkyness, or the lcd panel itself is not seated properly. Also the memory driver for the lcd panel can be messed up in some way.
Bottom line, if you are getting a green tint even on the menu then it would be a problem you would need to have addressed by a trained technician.
For now, you can try to do a through cleaning and try to dust out the light path.
I do not know how deeply you want to dig into the thing but if you can get to it make sure the optics are clean.
Also look into the optical path while it is off and try to locate any weird films or dust. Sometimes hard to spot I know.
Good Luck.
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: 46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
IT SHOULD BE UNDER WARRANTY. TAKE IT TO AN AUTHORIZED VIZIO SERVICER.
For the 46" TV, it sounds like the main board is bad.
For the 50" Vizio: is the LED light on?
