Washing Machines Logo
Germn Len Posted on Mar 12, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Codigo de error E-12 lavadora maytag mfr35 pnd
Chris Walker
Level 3:
Top Expert:
  • Maytag Master 1,573 Answers
  • Posted on Mar 15, 2019
Chris Walker
Maytag Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244345
Points
21965
5 Related Answers
A
Anonymous
  • Posted on Nov 05, 2008
SOURCE: Lavadora samsung dosnt spin
  1. Puede que el motor no gire en la direccion requerida ya que son reversibles
  2. El cloch esta danado
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Jun 12, 2010
SOURCE: codigo de error E 703 en sharp arm 550
LSU trouble
Anonymous
  • 381 Answers
  • Posted on Nov 10, 2010
SOURCE: 12 51 55 codigo de error
12 just means the system was reset recently 55 mean end of codes so don't worry about them 2 however code 51 is an oxygen sensor error (O2 Sensor) a bad or shorted O2 sensor can cause it to run very bad and get poor gas mileage.
gopakumarg43
  • 76851 Answers
  • Posted on Dec 07, 2015
SOURCE: Por favor donde obtengo los codigos de errores de lavadora IPSO mod CW8.URGENTE
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
gopakumarg43
  • 76851 Answers
  • Posted on Feb 25, 2016
SOURCE: mi lavadora sigue todo el proceso del programa se llena y cuando debe empezar a lavar se detiene, emite un pitido y sale un codigo de error en la pantalla dE. La E parpadea
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Reset code
Hola la manera de borrar los codigos en lavadora balay ts50100, poner selector en 0 pulsar boton de encendido y manteniendolo pulsado girar selector hacia la izquierda un toque sino se borra sin soltar el boton poner selector en 0 y repetir lo anterior hasta que se borre el error.
Codigos de error de lavadora kenmore elite he4t
MY washer Machine kenmore he4t have a errore code HF
Mi lavadora maytag neptune tl no lava y marca codigo od
El c?digo de error "od" en una lavadora Maytag Neptune TL generalmente indica un problema relacionado con la apertura de la puerta. "od" es una abreviatura de "Open Door" (Puerta Abierta en ingl?s). Aqu? hay algunas acciones que puedes tomar para solucionar este problema:
  1. Verifica la Puerta: Aseg?rate de que la puerta de la lavadora est? completamente cerrada y que no haya obstrucciones que impidan que se cierre correctamente.
  2. Reinicia la Lavadora: Intenta reiniciar la lavadora. Descon?ctala de la corriente el?ctrica durante unos minutos y luego vuelve a enchufarla. Esto puede restablecer la electr?nica interna y eliminar el c?digo de error.
  3. Inspecciona el Pestillo de la Puerta: Verifica el pestillo de la puerta para asegurarte de que est? funcionando correctamente. Si el pestillo est? da?ado o desgastado, podr?a necesitar ser reemplazado.
  4. Comprueba el Cableado: Examina el cableado que conecta el interruptor de la puerta y el panel de control. Aseg?rate de que no haya cables sueltos o da?ados.
  5. Sensor de la Puerta: Algunas lavadoras tienen un sensor de la puerta que puede fallar. Consulta el manual del usuario de tu lavadora para obtener informaci?n espec?fica sobre la ubicaci?n del sensor de la puerta y c?mo comprobar su funcionamiento.
  6. Llama al Servicio T?cnico: Si despu?s de intentar estas soluciones el problema persiste, es posible que necesites la asistencia de un t?cnico de servicio. Puede haber un problema m?s complejo con el sistema de la lavadora que requiera atenci?n profesional.
Recuerda que estas son sugerencias generales y pueden variar seg?n el modelo espec?fico de tu lavadora. Siempre es recomendable consultar el manual del usuario de tu electrodom?stico para obtener informaci?n espec?fica sobre los c?digos de error y las soluciones recomendadas. Si no tienes el manual, puedes buscarlo en l?nea o contactar al servicio de atenci?n al cliente de Maytag para obtener asistencia.
Yo tengo en la lavadora el codigo f-21 what is this
F21 de error se muestra cuando la lavadora no se puede drenar, pulse Pausa / Cancelar dos veces para borrar la pantalla. Despu?s de esto, por favor revice la manguera de drenaje y filtro de la bomba de drenaje para los bloqueos y asegurarse de que no est? obstruido con part?culas extra?as. Tambi?n puede consultar la bomba de drenaje para verificar que su funcionamiento.
Si necesita m?s ayuda, consulta otros consejos en este enlace: won_39_t_finish_cycle_21_f_flashing
Esperamos que esta ayuda le sirva (recuerda votar y comentar esta respuesta).
16helpful
2answers
3helpful
Tengo una lavadora electrolux maxi clean y me manda codigo de error e4 que tengo que hacer
Buenos dias tengo una lavadora maxi clean que no centrifuga y los demas ciclos los hace sin problemas, como le reviso l control de nivel por que la bonba suena como si tubiera agua la tina por mucho rato.
Gracias
1helpful
Mi lavadora maytag neptuno lava perfectamente bien cuando llega al siclo de exprimido semueve mullo la tina y me dise el display que la ropa esta desnivelada la acomodo y buelve astar y gual
nivela las patitas de abajo.. si tu lavada tiene desnivel ( movimiento ) tu lavadora aa lo ismo una y otra ve P espeo te ayude saludos
especialista ZeRoC0ol
2helpful
Quisiera saber si hay que cambiar tarjeta
Checkas aqui... http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WTW6600&siteCd=WHRCOM porque hay informacion en espanol en los instruciones por tu lavadora.. los instruciones dice: Oprima Pausa/Anulación (PAUSE CANCEL) una vez para despejar el código. Presione Inicio (START). Si el código aparece nuevamente, llame al servicio técnico.
34helpful
5answers
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
