SOURCE: Need to replace the lcd in lumix(panasonic) dmc-fx3
ebay seller rongyuanxie about 55.oo or do an ebay search with these key words...
FX3 LCD DISPLAY SCREEN
hope this helps...
SOURCE: Panasonic DMC-FX3 doesn't detect memory card
Hello Janaecooley,
The card section of the camera must be cracked or damaged due to fallen. First option is to get repair from any expert, Second option is that you want to get the pictures present in your memory stick. for this you can get you snaps to put your card in a CARD READER and save it at you computer. In market various card readers are available with very low price. Buy one that suits yous memory stick.
Thanks for using FIXYA!
SOURCE: message PLEASE TURN CAMERA OFF THEN ON AGAIN
Sometimes this message appears when force has been applied to the lens. Here are some things to try. Go into the setup menu and find "reset" to reset the camera. If that doesn't work, remove the card and battery...press all the buttons...insert the card and then the battery. You may have a lens problem that can only be repaired at a service facility.
SOURCE: my panasonic lumix dmc-fx3 camera does not turn
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
SOURCE: Should you use an 8gb sd memory card in a
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Hi
Thanks for using FixYa. You can buy the charger
from any of these links:
Please do rate the solution if the issue is
resolved or post a comment for further assistance.
Thanks
Rylee
Instructions for this simple operation should be given in the manual.
