Unfortunately, the Elna Lock L1 manual is not available for free online. You can purchase a printed copy of the manual here: https://www.sewingpartsonline.com/instruction-book-elna-l1-serger.aspx .
Since many parts of the serger are the same between models, the L4 manual may help set up the L1. The L4 manual is available at ManualsLib: https://www.manualslib.com/products/Elna-Lock-L4-3172471.html .
I hope this helps.
SOURCE: Hi, I am unable to do a overlock stitch , elna l1
Check with sewusa for a threading guide and manual.
Look inside the font door of the machine to see if there is a threading guide.
SOURCE: need a copy of instruction
on this link before you can download for free, enter the verification code in the box before hitting the Download Your Manual or Guide button
http://www.devicemanuals.com/guide/Sewing%20Machine/Janome/Janome-MyLock-204D-Instruction-Manual-T0RReE1UVT.html
on this link before you can download for free, rate first the survey before hitting the Download The User Guide button
http://safemanuals.com/314159.php?k=0a556051b21d342a449f042e4bc3b389&ID=2319947&q=JANOME%20MY%20LOCK%20204D
this manual may costs you
1. http://www.ps2netdrivers.net/manual/janome.my.lock.204d/
2. http://www.tradebit.com/indexNew.php/basket/add/32156721
SOURCE: manual for elna 614DE overlocker
try these sites for a manual
premiersewing.com
or contact elna customer service about a manual
SOURCE: although overlocker is correctly threaded it does not form a chain
here's a link for a manual
http://www.sewingpartsonline.com/instruction-book-elna-t33.aspx
try changing the needles & see if that helps the machine to form
a proper stitch, if it doens't then it's possible that the machine
could be out of time & needs to be checked at a sewing machine
shop
