SOURCE: kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
SOURCE: CHANGE THE LIGHT IN MIELE OVEN
Had the same problem. Ended up removing interior oven panels (sides first then top on model H310B). This is easier than you might think. Could then get a good grip on the light's glass cover and it unscrewed easily.
SOURCE: How to clean inside glass on oven door
If you can, usually it is possible, remove the door from the oven. open door to the first open position..(broiling) about 6" open then (make sure any screws are removed from hinges holding door in place) lift up and out at the angle the door sits.place on counter and start removeing screws. can be a whole bunch of em..
SOURCE: unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Below are instructions on how to take your oven door apart to
remove any stains that may be caught down in the door vents. Tools needed: good Phillips head screwdriver or small quad bit
driver. B. With door in broil stop position lift door assembly off
hinges. C. Lay door on table, position so that handle hangs freely over
edge of table D. Remove 2 screws and washers that secure handle to lining
assembly. E. Remove 8 screws that attach textured steel door wrapper trim
to lining assembly 3 at top, 3 at bottom, 1 on each side F. Lift door lining up and out of wrapper trim assembly. G. Lay lining assembly on table with wool shield/inner part of
lining facing up. H. Remove 2 glass clamps via 2 screws per clamp. These clamps
attach innermost clear glass to wool shield. I. Lift out center clear glass from wool shield, this glass
just lays onto the wool shield and is held in place by the glass/ clamps in
item
H.
K. One glass that remains in door lining assembly can at this
time be cleaned without further disassembly the lining assembly. L. Reassemble in reverse order.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
