Haier 4.0-cubic Foot Great Personal Compact Small Refigerator Box Mini Fridge Logo
BerylandDave Smith Posted on Mar 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thetfordn3112fridge all lights flash on control panal on all sorces
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 29, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244888
Points
21965
Defy 350lt upright freezer red alarm light flashing the light start flashing and the food started defrosting
Check for proper door closure or internal light function first
Next, check temp. control settings. If all checks ok, call a tech. to fix it
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Sep 21, 2017 • Freezers
2helpful
Setting the controls
These are computer run items now. If you unplug it for 2 or 3 minutes does it reset itself? If not try pressing refrigerator an ice buttons together. If that does not work the evaporator fan or control panel needs to be replaced. That about all one can do these days other than keeping the air ways clean so fan is clear. But ecen that will not stop these voltage spikes on the line from ruining good appliances.
Why is the pilot light on my ERN7926 frost free flashing?
To Start the Appliance
Allow the appliance to stand for 2 hours after
installation. Plug in the appliance and switch on at the mains
supply. Turn the thermostat control (B) to a midway
setting and adjust the slider control, situated on the
back wall of the fridge section, to a midway position
between "MIN" and "MAX".
The pilot light (A) will illuminate. Leave the appliance for approximately 4 hours for the correct temperature to be reached before placing food inside.
To switch off the appliance turn the thermostat
control to position "?"
After 4 hours, measure the temperature in the refrigerator and freezer. Should be between 2 and 10 degrees centigrade in refrigerator and app. -18 in freezer.
Dado
1helpful
First the freezer alarm beeping with red light flashing, inside light went out and freezer standard electronic temperature control display unit no longer lights up.
Hi Loretta, I am happy to assist you!
Based on the symptoms you are describing, it sounds like your freezer may possibly have a communication problem with the control board, a potential wiring failure, or faulty temperature control. Before reaching out to a professional, let's try resetting your freezer. This can be done by either unplugging it or flipping off the circuit breaker. It is important to wait approximately ten minutes. If it proves ineffective, In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the exact diagnosis of the appliance.
Best regards!
Nup right freezer model # 2532240210 I defrosted then turned back on and all the lights on outside of door is flashing is there a problem?
Does the unit have a digital control on the door? If so try unplugging the freezer for about ten seconds to reset the control. If they still flash replace the digital control. If you do not have the digital display, and its just an orange light at the bottom, then no worries they sometime flicker
Freezer forms ice on botom under tray panal and water runs down in fridge
you have a iced up evaporator, try defrosting it by switching it off for at least 12 hrs, check timer and defrost heater.
May 03, 2009 • Freezers
26helpful
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 • Freezers
1helpful
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 • Freezers
Servis fridgefreezer light
IT COULD BE A BAD LIGHT SWITCH, SOCKET OR BULB.
IF THE CONTROL IS ELECTRONIC, SOME REFRIGERATORS WILL SHUT DOWN THE LIGHTS IF THE DOOR IS LEFT OPEN TOO LONG.
BE SURE THE BULB IS SCREWED IN ALL THE WAY. SOMETIMES, THEY WILL WORK LOOSE.
Apr 02, 2008 • Freezers
Top Haier Freezers Experts
NOEL
NOEL
Rob Hill
Rob Hill
Are you a Haier Freezer Expert? Answer questions, earn points and help others
