SOURCE: program
Try to see if it flashes an error code, that could help identify the problem. Otherwise, if the problem is only with programming and not with the actual dishwasher, you might want to try replacing the program timer module.
SOURCE: Washing Machine LG WD-8013F
it may be the lock but this model is known for board faults,take of the top panel and remove the control panel and see if the board is burnt.there was a recall on some of these machines a while ago in australia not sure where you live
SOURCE: When switched on the pumpbutton stays red and the
Thanks to a manual that was sent to me I understould I had to press the button P for a long time, that resets the machine. Thanks for your service! Carolijn
SOURCE: rEQUIRE A MANUAL FOR sMEG sa 880 X DISHWASHER as
Go to Sears.com, select repair parts, enter model # where indicated, request online manual. you can review manual on your computer.
SOURCE: 2005 GMC Yukon XL-
It is probably the encoder motor attached to the transfere case. look under the vehicle to see if there is signs of corrosion between the encoder motor and transfere case.
