SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
SOURCE: Not enough water coming into dishwasher. How do
If not enough. take apart the source hose and the inlet valve and look for restrictions..Machines now days use less water and the inlet of water is timed and not controlled by the float switch, soooo restricted water means you have less water.
I would disconnect the hose at the inlet valve, put it in a bucket and test it's flow. Sometimes the rubber washer deteriorates in the shut off valve, under the sink, for the dishwasher.... But both the hose and the inlet valve to the machine can have screens that plug up...
Doc
