Cell Phones Logo
Michelle Bowers Posted on Mar 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the Casio G'zOne Type-S flip cell phone have a SIM card or a memory card and if yes where is it
Level 3:
  • Casio Master 6,688 Answers
  • Posted on Mar 10, 2019
Cindy  Wells
Casio Master
Level 3:
Answers
6688
Questions
0
Helped
3530668
Points
21745
The Casio G'zOne Type S does not have a user-replaceable SIM or a slot for a memory card. The specifications are available here: https://www.phonescoop.com/phones/phone.php?p=1083 . The permanent SIM card is common with Verizon phones.
I hope this helps.
5 Related Answers
Anonymous
  • 28 Answers
  • Posted on Jun 18, 2007
SOURCE: Transfer contact number from Sim card memory to Phone memory?
you go to menu,contacts,name,choose name,options,move or copy contact.
Artur Heise
  • 232 Answers
  • Posted on Apr 26, 2008
SOURCE: installing the memory card in my Treo 650 cell phone
there's a card slot on top of the device - see pic attached (which shows both - SIM card and memory card slot opened). To open it press down and release dummy card, thenn pull it out and put SD card into slot (pushing it slightly deeper)5deba98.jpg
You can back up your Treo to either your PC or your SD
card. If you back up to your PC via hotsync, then there is a nice freeware which
can be installed to your Treo that is called SyncAll (all one has to do is right
before the sync, open the program and click "force all to sync"), and it will move
all the files, including preferences and such that don't normally get sync'd. If
you backup to your SD card, there are numerous programs for accomplishing this. It
is important that the number of backup-to-SD programs are limited for the Treo 650
due the NVFS file system. You can try THIS ONE for example - it's free.
Anonymous
  • Posted on Sep 22, 2008
SOURCE: CELL PHONE FELL INTO THE WASHER
If you have insurance, it will probably cover water damage. The warranty will not. If you want to try to fix it yourself, read on.
Taking the battery out immediately is essential in order to prevent short-circuiting between leads of delicate components or the components themselves. However, the common misconception of then drying all of the circuit boards and components without specifically cleaning out the moisture first will probably ruin your phone. Let me explain. When the circuits get wet, many unintended current paths are created through the liquid. That's why it is important to remove the battery ASAP and leave it off until the repair is finished. However, the most common type of damage occurs after the electronics dry off. Sure, the water is gone, but any dissolved solids in the water remain. These deposits (sugar, coffee, soap, minerals from tap water, etc) remain and dry on the electronics as a hard film that can't be removed. These deposits will affect the digital and radio-frequency circuits of the phone, rendering it junk.
The solution is pretty simple. If the phone gets wet (dropped in a toilet, soda spilled on it, gone through the washer, etc), remove the battery and keep the phone wet (put it in a ziploc baggie) until you can clean it with DISTILLED water. Distilled water has no minerals in it, so it will dry without any residue left behind. DO NOT USE TAP WATER. Disassemble the phone completely, and use a syringe to spray everything off. Pay special attention to the circuit boards, chip leads, ribbon cable connectors, and anything else that looks electrical. Don't be afraid to get the electronics wet. That's what we need to do. The idea is to ensure none of the original liquid is remaining. Once completed, shake off the excess water, and place all of the components in a warm dry place for 24-48 hours. Once dry, reassemble the phone and enjoy it.
I have used this procedure 6 times, and it was successful 5 times. One morning my wife called me and said my son's phone had just gone through the washer. I had her rinse it off under the faucet with tap water to get rid of the excess soap and put it in a baggie to keep it wet until I got home. That night i used this procedure to repair it and the phone worked fine. The 1 time it didn't work, some soda had already dried on the circuit board and I couldn't get all of it off.
Anonymous
  • 6 Answers
  • Posted on May 16, 2009
SOURCE: transfer contacts from a sim card onto cell phone
Go to contact list and select the contact.press option button then press copy option then press copy to phone.
Roosevelt James
  • 398 Answers
  • Posted on Dec 10, 2009
SOURCE: Does my Verizon cell phone (Samsung SCH-U410) have a sim card?
No sim card. verizon has an application called Backup Assistant.. It is free if you havea My Verizon account. 1.99 if you dont. It is fast take about 2imutes.Thats if you are staying with Verizon changing , upgrading phones
3answers
How to transfer contacts from Sanyo flip phone
just copy your contacts or move your contacts from your phone memory to sim card memory from Contacts setting menu. and paste it on any other IOS or android drive and import contacts. then again put your sim card in flip phone and first empty the sim card memory and repeat the same procedure;
G'Z one phone powers on but just says loading
Probably your phone's operating software is corrupted, u need to re-flash it
U can remove the remove the memory card completely and then try to restart phone but generally memory card has nothing to do with it,
Do I need a sim card for my phone to work?
Referbised phone doesn't come with a SIM card. You should be able to turn it on. However, you need a SIM card to make calls and sent messages.
How can I download pictures with no screen with the G'zOne?
If it has a memory card, with photos stored on it you can put the card into your computer reader and download them. Otherwise, you need to see it you can find software (use google to search) for your phone and use cable to connect it to your computer. If neither of these work, trash the phone and chalk it up. Get one that uses a memory card.
Does this phone have a sim card?
No, it's a CDMA network phone on the Verizon network which doesn't use sim cards.
Trying to find where bluetooth info is located on phone it is a casio g zone
hi,
Setting & Tools
My Verizon ~ Tools ~ Bluetooth Menu ~ Sounds Settings ~ Display Settings ~ Phone Settings ~ Call Settings ~ Memory ~ Phone Info
In tools you get Bluetooth info
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
How can i replace sim card G'zOne type-s
You'll need to contact the company you have (AT&T, T-Mobile, etc) to get a new one.
2helpful
Ringtones
you have to format the memory card first to the phone.. easiest way to do this is to take a picture from the phone and transfter it to the card...
at this point the card will now have folders associated with the phone on it..
if you put your sd card into your computer and see any files that are not in a "my_pix, my_flix, my_ringtones etc" folder, drag them to the appropriate folder and you will be able to access them through the phone
so if you wanted to do ringtones drag the music into the ringtones folder. if you wanted music drag it to the music folder
Can my gzone type s be repaired
i had this same problem. Fixing it cost twice as much
AT&T
There is no way, different networks. AT&T uses sim cards to identify its users. Sorry.
Top Casio Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
