Most garage openers have a reprogram button on the lift motor. You push the button on the motor and enter in the new code on the keypad but you only have a really short time to set it so get someone to push the button from a safety ladder and you can set the code. You hit program and then push your code numbers.
SOURCE: My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
SOURCE: clicker garage door keypad works inconsistently
no relation. did you plug rpm sensor and logic board connectors on well.
SOURCE: Chamberlain garage door opener unit-is it compatible with craftsman keypad?
Hello,Linda well this is your lucky day ,I have installed garage door openers for sears for 10 years and i can tell you that craftsman,chamberlain ,and liftmaster are all the same machine and manufactured under the liftmaster name , if you buy it from home depot it will be a chamberlain ,if you buy it at sears ,it will be a craftsman, and if you go to commercial building supplier it will be a liftmaster! now getting that out of the way even though they are all compatible ,there is one thing that stands in their way and that,s time ,For example if your chamberlain machine is 5 years old and you went to sears last week ,the chances of the frequency being the same are not good , most likely you have the wireless keypad , one way to test the sears keypad against the chamberlain machine is to locate the smart button on your machine ,this button allows for programming of remotes and keypads , to test and see exactly what im talking about take your remote and locate the smart button ,if you have three buttons on the remote press one of the buttons that are not being used on the remote ,above the smart button their will be a blinking light ,if you press your remote button you will notice the light go from a blink to a rapid flash , This is telling you that you are sending a signal for programming to the machine , well the keypad is exactly the same all you have to do is push the enter button on the keypad and have someone watch for the rapid blinking light ,if they are compatible the light will blink rapidly on the machine so all you have to do now is have someone press the smart button once on the machine your indicator light will now be a solid light you will have approx 60 seconds then to put a 4 digit code in the keypad and then press and hold down the enter button on the keypad , at this point you will notice the lightbulbs on the chamberlain machine to shut off and come back on this is to tell you that the machine accepted the code , after thats been done you can use your keypad , you can also find the owners manual to the chamberlain and follow the same instructions to programming the remote , they are identical in programing , if your keypad is not the same frequency you can also tell by looking at the frequency code on the backside of the keypad and also the chamberlain unit usually where the light bulb is will be its code
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
SOURCE: I have Craftsman TX2028 remotes (139.53753) with
Make sure the green light in the wall control is not blinking. If it is, press and hold the 3 seconds the lock button.
