This sensor sends temp reading to inside receiver. The sender is not sending
SOURCE: pop3 server does not respond in 60 seconds
if the server is still NTL try to manualy reconfigure the settings, here are the settings you need: Protocol = POP3
Incoming Mail Server = pop.ntlworld.com
Outgoing Mail Server = smtp.ntlworld.com
hope this resolves the problem
SOURCE: brother fax 4750e can not receive or send fax.
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
SOURCE: Where is the coolant temp sensor on a 2003 escort zx2?
there are 2 item located in the same area one is a little below the other.it is on the housing of the one you replaced, the top one is a low coolant sensor and the one on the bottom is the temp sensor.
SOURCE: cant send or receive music files on yahoo messenger anymore
check to make sure the firewall is open to yahoo
SOURCE: The outside temp sender won't work. We put new
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
