SOURCE: Hitachi
Go to menu look under cable/air switch to cable if you have cable then look for Auto Programming press go this will then automatically program all channels that you reviced, a universal hand unit can not do the things that your hand unit can do ! If you need more help let me know.
SOURCE: need help programing my vizio tv to a blackweb universal remote
You don't program the TV to the remote, you program the remote to the TV
Find the Vizio codes on the paperwork that comes with the remote. There will probably be several codes. You need to try each one. Before programming turn the TV on manually. After put in each code try turning the TV off with the remote. Then try to turn back on and try volume up If OK everything else should work. Occasionally 2 different codes will turn off the TV in the test above. Use the one that allows the most functions to work
FINALLY not every "Blackweb" remote will control every TV You may need to get another one that specifically says it can control Vizio.
