Casio lk 70s keyboard key lighting
You can find the software for Casio LK-70S here: https://support.casio.com/en/support/download.php?cid=008&pid=20 .Look for the driver for the keyboard under the Digital Keyboard/Piano (excluding the PL-40R). Select the appropriate link and then scroll down to the Download button. Another file is the SMF converter. The conversion software is here: http://music.casio.com/e/smf/ . Scroll down to find the download links. This software works with Microsoft Windows 98 SE, Windows XP (32-bit) and Vista (32-bit).
I hope this helps.
SOURCE: Need replacement key set for Casio LK-110
You would need to call casio for such parts or go to a part store which by googling it you can find the parts for this unit.
SOURCE: I want to transfer some
The keyboard will NOT show up on MY COMPUTER as it does not have memory to record and save MIDI files... It will PLAY them real time as the computer sends the data to the keyboard. You can't transfer and save the files IN the keyboard. Some higher level keyboards do have memory and even hard drives... this one does not. This one will have some built in,that you can play but even those you cannot access as if they were memory.
With the USB cable connected, you should be able to see the device listed in the device manager section of the control panel under system hardware.
SOURCE: the keyboard works fine but
Read your manual regarding "fingered chords" and similar subjects. It sounds like you are in a single fingered chord mode...
SOURCE: Need an owners manual for a Casio lk-100 keyboard
you nearest casio dealer may have one in the back of the store,
many buyers don't want/need the manuals so some stores hold on to them for such occassions
SOURCE: How do I factory reset Casio lk 110 keyboard?
Unplug while unit is on. Then press and hold power button for about a minute. Replug back in see if that does trick. If not call company for a hidden code if available.
