Trial and error. try each of these codes down the list until one works.
https://codesforuniversalremotes.com/remote-control-codes-for-philips-tvs/
SOURCE: philips remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: i need codes for philips universal remote control
I have a phillips universal remote, that I brought in Georgia. I have lost the instructions for programing.
My television is Emerson and I need the codes and instructions. Please help.
SOURCE: need universal code for philips sru3004 universal remote
here are some sites with your code.
www.remote-codes.com
www.tvcodes.com
www.universal-remote.net/philipsmagnavox.html
SOURCE: I need Philips CL035A codes list for toshiba tv
I believe this is your remote. it's listed as pm435s
http://www.p4c.philips.com/files/u/us2-pm435s/us2-pm435s_dfu_eng.pdf
these are the codes for toshiba
0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0627, 0437, 0041, 0094, 0802, 0111, 0313, 0715
