Washing Machines Logo
I have a front loaded Samsung washing machine Model # Samsung WD7704C8C. First it was not Rinse and spin properly. When it reaches the spin cycle the wash starts all over again and the minutes are reading inaccurate. Now, even when I start washing, then after 3 minutes washing, it stops. Then I unplug and try to on the machine but not. then after some couple of hours, it becomes on. Now it is again become off. No power. What should I do?
1 Related Answer
SteveAlaska
  • 107 Answers
  • Posted on Feb 04, 2017
SOURCE: My samsung washing machine Model # WA5471AB is not spin drying...when it reaches the spin cycle the wash starts all over again and the minutes are reading inaccurate...PLEASE HELP!!!
Sounds like a mother board problem. If you're handy, take the panel off and reseat all connectors. Don't forget to unplug the machine first.
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
1helpful
Samsung b1445v front load washing machine will not pass prog. 8 even when empty, then code ue
This is an error caused by the cycle advance which acts like a timer. The main control board can cause this issue. Diagnostic testing will need to be performed to determine the cause of this problem
My washer seems not to spin properly during the rinse cycle and will not spin now i get what i assume is an error message ue when its time for the spin cycle to begin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Model #26842691, Stock # 26842. It will go through the wash cycle, but it will not drain to go to the spin cycle or rinse cycle. It won't forward on. It just sits their.
heatman101
1helpful
2answers
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Kenmore Model 22722 will not drain
heatman101
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
1helpful
2answers
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Zanussi Model FLA 1002W Washing m/c.
my w.m. is very noisy, after cycle laundry is with black spots on and white bits on clothing but it is not tissues. ?
2answers
Shuts itself off before each Rinse or spin cycle.
Maybe your spin or rinse cycle button is in the off mode. Refer to your user's manual, if you hv one.
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
