Baby Gear Logo
R
Robyn McCormick Posted on Mar 08, 2019
Assembly instructions for tagies peaceful snuggles leafscape swing & sway
Kaelee Vogt
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 12, 2019
Kaelee Vogt
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
472
Points
3 Related Answers
Anonymous
  • 196 Answers
  • Posted on Jul 28, 2010
SOURCE: Fisher price 3 in 1 swing
try looking on the website www.fisherprice.com for instructional manuals . jackie
mccluskey1
NOEL
  • 8606 Answers
  • Posted on Mar 29, 2015
SOURCE: The volume is very low on my child's Greco sweet snuggle swing. Can hardly hear the song that's playing
could be a small bit of dirt on the inside of the volume switch,
try spraying w.d40. then just keeping turning it up and down to see if it clears it.if it crackles as you turn it up or down then its just a bit of dust on the switch.
terryskelly
Terry
  • 11377 Answers
  • Posted on Apr 03, 2015
SOURCE: How to disassemble the graco snuggle swing
Could this be what you are asking?
Convert Baby Swing from Batteries to AC wall Power
2answers
Bali garden swing assembly instructions
Hello, Joseph -
I have found reference on web pages to more than one garden swing with the name "Bali." I don't know if you mean "Bali" as a brand name or if it is just part of the descriptive name of the garden swing or if the swing was originally made in Bali. I also have no idea if your garden swing is wood or metal.
I have found some instructions online for garden swings. Perhaps one or more of the instructions will demonstrate how to assemble your garden swing.
See:
YouTube videos:
https://www.youtube.com/watch?v=uKfBmrgj5Bw
https://www.youtube.com/watch?v=c_pM4D-7m70
PDF documents (free Adobe Acrobat Reader software needed):
https://c.searspartsdirect.com/mmh/non_lis_pdf/OWNM/2_SEAT_PROMO_SWING_S80A24.pdf
https://www.numarkcustomerservice.com/v/vspfiles/img/Stores/Walmart/Sullivan%20Point/SC-K-454GS_Assembly_Instruction.pdf
https://www.argos-support.co.uk/instruction-manual/3560877-culcita-3-seater-garden-swing-chair.pdf
Could your Bali garden swing be one here:
http://www.visionbaliexport.com/furniture/garden-furniture/garden-swing.html
If so, on that web page, look in the upper right corner and click or tap on Contact Us. Use the form on the Contact Us page to send an email message asking for assembly instructions.
Best wishes.
Apr 14, 2018 • Garden
I need to disassemble my fisher price snuggle bunny swing
I have never heard of a dis-assembly instruction sheet, however, when you buy one, there is an assembly sheet, if it is not assembled already.
A mechanic-type person should be able to figure this out for you.
God bless your efforts.
Cosco swing and play music plays but does not swing
Take it back they will replace it for you for up to 2 years.
Need assembly instructions on how to put together sway n soothe bassinet from first years ... Now Please about to donate it to Joplin Relief Missions
If you notify sway and soothe bassinet's makers first years, it should have a set of instructions on line to print out..if not call them/email them and get them to send you some. Good luck!
Jun 05, 2011 • Toys
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOPâ„¢ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITEâ„¢ SWING On the bottom of the contoured plastic seat
  • SWEETPEACEâ„¢ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHEâ„¢ SWING + ROCKER On the underside of the housing
  • DUETCONNECTâ„¢ SWING + BOUNCER On the underside of the housing
  • DUETCONNECTâ„¢ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGERâ„¢ Inside leg near Rock Lock
  • DUET ROCKERâ„¢ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAYâ„¢ INFANT SWING On tubing on bottom of unit
  • COZY DUETâ„¢ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDERâ„¢ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 • Graco Toys
Little Tikes Swing Along Castle
Your 4 screws may hold the swing piece to the slide piece. You actually secure it to the slide side wall with one of the red screw caps but you can also secure it with 4 screws that screw into the plastic.  You can also find the manual and assembly instructions at littletikes.com
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
