Washing Machines Logo
Posted on Mar 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have an old Bosch Clasixx 1200 washing machine that has been a great workhorse for many years. However, lately the laundry is cold when the cycle finishes. Is there a part that I needs replacing?
The cycle completes without issue but the laundry used to be hot/warm on completion. Now it is totally cold immediately after the wash finishes.
CJ Rock
Level 3:
  • Bosch Master 4,417 Answers
  • Posted on Mar 08, 2019
CJ Rock
Bosch Master
Level 3:
Answers
4417
Questions
0
Helped
1642185
Points
14985
First check the if there's a debris screen on the got water inlet, as it may be plugged. Make sure the hot water volume is good. With hot water hose disconnected at the washer, put end of hose in bucket and turn on hot water. You should get 20L (5Gal) a minute minimum. If water volume is good and screens are not plugged, then likely the hot water inlet valve has seized. Could be both hot/cold valves are integrated so both get changed. Not a bad idea to just do them both if separate hot/cold valve.
If you know how to use a volt meter you could check power at the hot valve to make sure its not a control issue or swap the control wires and select a warm temp cycle. If you get cold water then its not a control issue.(dont forget to put wires back)
  • 5 more comments
  • daveyburton Mar 08, 2019
    This machine has always only been used with a cold water inlet only. I have definitely experienced warm/hot laundry in the past
  • CJ Rock
    CJ Rock Mar 13, 2019
    I make no sense of "only been used with a cold water inlet". How do I reconcile "used to be hot/warm on completion" when you apparently only have cold water connected? Please rephrase the problem?
  • daveyburton Mar 14, 2019
    Machine takes input from a cold water source only. Always has.
    In the past the machine would heat the water and on completion the laundry would be warm to the touch.
    Now it is always cold.
  • CJ Rock
    CJ Rock Mar 14, 2019
    Now I understand. Thank you. So something with water heating element relay or control. I'll get back to you. See if I can find more specific to this model... apparently no one else knows much about this one either.
    Thanks Carl. Appreciate it.
    This is a really old machine but it has been good to us.
    Would be nice to repair rather than replace.
    Dave
  • CJ Rock
    Do you believe hot 90C is reaching 90C? or is it significantly less. I suspect
  • CJ Rock
    a temperature sensor failure/failing.
5 Related Answers
Bob Gemmell
Bobby G
  • 212 Answers
  • Posted on Sep 13, 2007
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Anonymous
  • Posted on May 11, 2008
SOURCE: bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Anonymous
  • Posted on Jun 04, 2009
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Anonymous
  • 14 Answers
  • Posted on Jul 07, 2009
SOURCE: Samsung J1455AV: Washing cycle does not complete and then stops
go back to where you bought it and have the engineer look at it might have been faulty when bought.
prem mathew
  • 662 Answers
  • Posted on Jun 17, 2010
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
tip
How to fix Bosch Classixx 6 washing machine pump fault
My Bosch Classixx 6 Express 1200 washing machine suddenly developed three faults at the same time, with no fault codes. The water pump, fill and spin cycles all stopped at the same time. I found that the one of the pump wires had come loose from the connector plug. This will not only stop the drum from emptying but will prevent the machine from filling and also stops the spin cycle. These are all interconnected and controlled by the water pump, which has to be working and connected. Hope this helps. My 11 year old machine is now working perfectly. ,
on Feb 23, 2019 • Washing Machines
Does the Bosch Exxcel 7 1200 Express have a child lock function?
try the manufactures website for free manual download
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
2answers
Conditioner remainig in dispenser
Bosch clasixx 1200 front loader This video will show you how to keep your soap draw clear and how to service the parts
2helpful
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
1helpful
3answers
I have a bosch clasixx 1400 washing machine and it is not spinning but is going through all the programmes and i have also changeed the carbon brushers, what is wrong?
Make sure the filter is clean, this is located at the bottom front right of washer, unscrew anti-clockwise to remove and clean.
Bosch classixx 1200 washing machine stalling mid-cycle
Thanks, roman
9helpful
3answers
Fabric softener stays in drawre
I had this same problem to
If you take out the drawer of the washing machine and look upwards there are 4 very very small holes get a pipe cleaner and giver them a jolly good clean.
This should then solve the problem
3answers
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
