SOURCE: How do we adjust our tv
You didn't mention anything about a cable box, VCR, etc. which might be connected. A snowy pic. means simply, inadequate signal is reaching the tuner, or the TV tuner itself is bad. If the first is so... check your cabling. If you have a VCR or DVD player hooked in between the cable box or outside antenna (whichever is the case), VCR (RF or ant.) out should go to the TV, VCR antenna (RF or ant.) input to the cable box. Also check the cable wire itself. If you look at the end of the cable, you should see a relatively thin center wire. This center conductor is what carries the signal. If it is missing, bent over, or too short to make contact with whatever it is connected to, you will have a very snowy pic. If you have a spare TV, connect it in place of your "new" TV, to narrow down the problem. Lastly, if all is well with hookup, cabling, etc. the TV might have a problem. Sometimes the tuner has a component defect, or the coaxial connector can be broken.
SOURCE: sound problem
SOURCE: Sony KV36HS500 Flyback Shorts
I HAVE A SONY CRT TV, BUT THE TUBE IS BROKEN. i BELIEVED. THE TV IS
Sony KV36HS500
SOURCE: I have the Sony KDS-
I have a older 2006 SXRD rear projection TV. I had the same problem after the TV warmed up this yellow tint started in the corner and crawled its way down the TV. It turned out that Sony had a recall on the optic block of the TV. If you replaced the Lamp and adjusted the color this kinda sounds like the same problem. Here is a link explaining it. In this article it shows up as a green haze and blob, but in my TV it manifested as a yellow tint.
http://www.avsforum.com/avs-vb/showthread.php?t=1086180
SOURCE: HORIZONTAL OUTPUT TRNSISTOR SHORTS WHEN POWER ON TV
hi in tv monetor crt use vertical yoke conaction ok when horezantal yoke conact then tv short pozetion 110volt 42 volt help please
