Washing Machines Logo
P
Pierrette Guenette Posted on Mar 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does clothes get stuck under my Frigidaire stackable washer
Stephen Miller
Level 3:
  • Frigidaire Master 1,645 Answers
  • Posted on Mar 06, 2019
Stephen Miller
Frigidaire Master
Level 3:
Answers
1645
Questions
0
Helped
864929
Points
9471
Http://www.fixya.com/tags/clothes_stuck_agitator_washing_machine/browse/frigidaire
To prevent clothing from knotting and twisting:
  1. Avoid mixing heavy items with light items.
  2. Avoid putting too many or too few items in the washer.
  3. Make sure you set the proper water level for the size load you are doing. ...
  4. Never wrap the clothes around the agitator. ...
  5. Be sure your wash water is not too hot for the fabric
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Dec 09, 2008
SOURCE: STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
tzweeb
Tom Zwiebel
  • 318 Answers
  • Posted on Jan 06, 2009
SOURCE: clothes stuck under the agitator
you really have clothes stuck under the "wash plate" it has almost zero clearance and would be very hard to get something stuck under the wash plate.
if you do have something stuck, then remove the 1 1/2 inch cap in the center of the plate, then a 7/16th bolt that holds the plate down. then grab the wash plate and lift up to remove it.
next time check your pockets and dont let this happen again, it could ruin the outertub by cutting a hole thru it and then leaking.
Wayne Holden
  • 512 Answers
  • Posted on Sep 03, 2009
SOURCE: I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Anonymous
  • Posted on Dec 02, 2010
SOURCE: How to disable buzzer from frigidaire gallery
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Anonymous
  • Posted on Feb 13, 2011
SOURCE: my frigidaire stackable washer/dryer will not drain water or do anything past filling up
my washer fills up with water but will not drain
2answers
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
13helpful
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
The tub has a crack stackable washer machine.told
If you bought it brand new in 6/08, try calling Frigidaire yourself and see if they will replace the tub for you. It can't hurt to try.
Excessive spin
I had this issue when I first purchased my stackable washer.. Because it was still under warranty, I had someone check it out. Apparently when it was installed they forgot to take out the security clamp that secures the unit during delivery.. duh!!
4helpful
2answers
Dryer drum has come loose, how do I tighten it?
These machines have a metal ball (like a small trailer hitch ball) mounted on the rear of the drum that rides in a plastic saddle mounted on the rear of the machine,
The parts that you need to replace would be the plastic glides mounted in the front of the drum that run on teflon pads glued to the rim around the door. When they get bad you start to notice dammaged clothing.
The drum is allowed to sag down enough that clothing can get into the gap at the bottom and as the drum turns upward the items get pinched when the gap closes at the top.
All these parts can be replaced but be prepared if you do it yourself, this is a tough machine to work on.
Good Luck
Quentin
2answers
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
