To delete stored files on the disk, look for the Access Stored Files icon on the main menu screen. (The manual shows the icon as either the right-most one on the top line or the left-most icon on the second line.) Press this icon to get a list of storage locations. Choose the storage area and then an individual mailbox, if you select the Mailbox icon. Select a file and press the Edit file button (second button from the left) below the list. The Delete button should show in a windows as the top left button. This function may be limited to the internal mail box that you can access.
If you need one of the stored documents, consider using the Send or Print options. The send or print the file by choosing the Delete after Send or Delete after Print buttons on the right side of each of these screens.
Canon has the documentation for the imageRunner Advance 4225 on the product support page: https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/multifunction-copiers/imagerunner-advance-4225/imagerunner-advance-4225?cm_sp=CSO-_-PFListing-_-imageRUNNERADVANCE4225 . See the manuals tab. The Access Stored Files information is shown starting on page 50 of the Basic Operation Manual. The current link is http://downloads.canon.com/cpr/pdf/Manuals/iRADV4200Srs_BOG.pdf .
I hope this helps.
SOURCE: My camera says that the
if there is a internal memory-which there proably is-remove card and hit playback and see if there are pics-if so either download or see if you can copy onto mem card inside camera through a copy function in playback menu-simply hit delete all or find format in menu and that wil clear internal
SOURCE: internal memory is full
it's most likely full of picture, or if you hvae any videos... but try connecting it to your computer using the usb cable it should've come with. then you computer will prompt you as how to put them in a file. after you double checked tht they made it onto your computer you can delete them off your camera.
SOURCE: tells me that the internal memory is full but
Remove your memory card. Go into the setup menu and scroll to "format" and follow the on-screen instructions. This will erase the internal memory.
Hi Lucy,
Try this:
Your print job is killing the printer's memory. a couple things to try:
1. disable spooling and print directly to the printer.
this almost never works, but from the control panel, open printers (and faxes) and right click on your printer and select "properties". the radio button to check is under the advanced tab.
2. print to an image first, print to another software printer, like the microsoft document imaging printer. then reprint from the .mdi file that is generated by it.
3. export your file to a non-publisher document.
file save as file type to something other than a .pub file. a .doc might work, then again it might muck up your layout.
a .jpg/bmp would work very nicely for printing.
4. increase the memory to your printer.
this option may not be possible for you.
