Freezers Logo
Ruth Matthews Posted on Mar 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have just bought a second hand service upright freezer I turned it on and the green light and the red light came on The red light The red light has an exclamation mark on it have any idea what it is
Chris Huff
Level 3:
Top Expert:
  • Master 6,289 Answers
  • Posted on Mar 07, 2019
Chris Huff
Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2018880
Points
74913
Red light should go out when freezer reaches operating temperature
5 Related Answers
sodeep
Sudeep Chatterjee
  • 3267 Answers
  • Posted on May 19, 2009
SOURCE: Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
Anonymous
  • Posted on Aug 23, 2009
SOURCE: new Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Anonymous
  • 523 Answers
  • Posted on May 05, 2010
SOURCE: The red warning light (exclamation Mark) is on?
check the condensor fan if it has one
Anonymous
  • 80 Answers
  • Posted on Jul 27, 2010
SOURCE: 2006 Ford Focus 1.8 diesel Red warning light
check make sure park brake is not on slightly, otherwise if ok check brake fluid, and top up as required, if low have brakes checked
Anonymous
  • Posted on Sep 27, 2010
SOURCE: BRADA MF-305 UPRIGHT FREEZER AMBER/YELLOW LIGHT ON
I bought the same freezer and have the same question.
Anybody know? Did you figure this out vemmy?
Should my green light be on at all times on my freezer and should temp be on normal
My green light stays on all the time unless I open the door and it needs to get back down to temperature. The red light will come on then and return to normal after 30 seconds to a few minutes if on a hot day. Good luck hope I could help
Upright freezer orange and red light on but green light off can you advise? Frigidaire freezer.
Draw fan has failed, temp unreachable over the past cycle of 24hrs, turn your unit off for 24hrs and defrost it, restart and should work fine for a few days, if so, replace fan and defrost element only. Call service tech for this unless you are clued in on this work, not that costly.
2helpful
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
New fan light running continuosly
lets see if i can help you out here, okay . Red is your hot power wire, Green is the ground which is screwed to mounting plate, black is negative, meaning no power.... connect your wires by color Red to Red , Black to Black , And if there is a green coming from the ceiling connect to mounting plate of fixture or vise versa. Remember to use eletrical scew caps, on all connections and do not leave any wires uncovered. Basically all your doing is a seperation of a wire from wires as you seperate a wire cap it off. then move to the next set and do the same. red to red black to black green to mounting plate . YOU WIL NOT BLOW ANYTHING UP IF THERE IS A WRONG CONNECTION, if all wires are of color follow these steps, if no color switch one wire try switch and vise versa YOU can do it
Red light on not green ...has to be green to freeze up again
Try to unplug it for about 5 minutes, and then plug it back in
Apr 17, 2009 • Freezers
7helpful
2answers
Philips whirlpool AFG 027 freezer
The orange button is the "turbo boost" - for reduzing the temperature the fast way. Mostly used when first time use or you put in a lot of unfrozen things at once. When reaching optimal temperture it goes off automatically. The red one is the alert button. Not sure about the green one. Under normal conditions none of the lights is on.
Apr 02, 2008 • Freezers
Freezer does not work
The unit may be stuck in a defrost mode.Check the timer.Turn the knob to take it out of defrost.The unit will start up when this is done and the defrost timer is the culprit.
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
