Model 7345V
SOURCE: action replay ds acting CRAZY!!! HELP ASAP HELP!!!!!!
when it is loading press a b start and select at the same time then let go when it starts after that update you action replay and all the games come back
SOURCE: Viper
did it ever work before?
A couple things here. It is best to have a "tach wire" and the system needs to be programmed to learn the tach signal in order to know if the car is running or high reving or dead. If it gets no signal of the sort the next option is voltage monitor, it monitors the voltage for an increase to show that the alternator is running. Either way that signal is not gettting to the viper brain or it has not learned that signal. You need an install manual, did you install the alarm?
