Televison & Video Logo
Sue Edgar Posted on Mar 03, 2019
Where to put the code from my roku tv - Roku Televison & Video
rdichoso
Level 1:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Contributor 6 Answers
  • Posted on Mar 03, 2019
rdichoso
Contributor
Level 1:
Passionate:
Habit-Forming:
Answers
6
Questions
0
Helped
3087
Points
19
You need to make sure you create a Roku account online then you can add devices to your account and enter the code here.. https://my.roku.com/link
6answers
Need to enter code for Roku 4 to stream to TV
It is easy to enter the code on your Roku device. By creating the Roku account You will get the activation code. Just put your activation code on your screen which shown below
After that, your device will be activated. Still, you want any step by step guidance you can visit the site:go roku com wireless How to set up your Roku Wireless Roku com
tip
Roku, How To Setup a Roku Player
You want to try the Roku player so you can stream NetFlix to your TV over your home internet connection. It can be a bit of a hair pulling experience to set one up. So I'll try and make it as easy as it can be. First; Once you receive your player, and connect it to your TV. You need to get your new player on to your home network, be sure you have a router with wireless capability's. You will need to know the name of your home network, and you will need to know your WEB key or the pass key to secure your access into your home network. To do this, go to "Settings" (on the Roku menu) then scroll thru the menu until you see "Network", press network, look for your home network and press on it, then put in the WEB key to access your home network router. Remember after each step unplug the Roku for 10 to 20 seconds to set the memory.(may take more than 1 time with some players) NEXT; Go to www.Roku.com internet site and set up your account with them, they will need info on how to bill you if, you use a pay chanel. So they will need some bank account info, Or you can use PayPal. Next On the Roku "My Account" page, down at the right bottom of the page you will see the "Link Player" button, follow this to input your Link code, or go to http://owner.roku.com/link to input the code. Then go to the Roku menu screen and finish the setup with your Link Code. This will now activate your new Roku player. Next you will want to go to NetFlix and set up an account with them. Same thing here, they need bank account info to bill you, if you stay past the free demo time limit. Now go back to your TV, Roku menu and scroll thru the menu to press on NetFlix, here you will go thru the Menu to get another link code. This time it will come on the TV, Roku menu to go back and put that code in your NetFlix account to activate your Roku player with NetFlix. Now in the process of all this, you may have to unplug your Roku player after each link code to set it into memory. This causes a lot of folks to have some trouble as they do not, "Turn Off" the Roku after they put in the network key, the Roku link code, then again after they put in the NetFlix link code. One last bit of help. Do not create a large Instant Queue on your NetFlix account over 50. This causes problems with the memory usage in the Roku player, and It can keep NetFlix from loading. Hope this helps FixYa up.
ROKU STICK IS NOT STARTING AUTOMATICALLY.
Check plug in roku stick and in electrical outlet for a good connection pull out and push back in..Their is a small reset button on ROKU,push it ,it will then show a blinking white light,if not you may have a bad roku stick.
Hook up ROKU stick BEFORE you put batteries in remote,after you put in batteries you will have to push button near batteries.
The remote should start blinking a green light this means it is trying to pair up with roku stick.If it does a purple sceen will appear on tv.Push home button remote and tv should give you a code.This code has to be entered at ROKU site link on computer.
I need dish network remote code for tlc roku tv
Yes you have to have a dish account in order to receive remote code to put in TLC or HBO go on roku I used my boyfriend moms code for my roku channels
RCA TV Converter Box DTA800B1. Codes for roku tv
For a Cablevision cable Provider the remote controller Model Number is UR2-CBL-CV04 and its remote device unique codes for Roku TV become 031, 081. To get a Charter Cable Provider the remote control Model Number is usually UR4U-MDVR-CHD2 and its remote control codes for Roku TV be 11756, 11602. The user on find their respective remote controller code, have to activate their Roku account using enter Roku activate code to get started on streaming their recommended shows.
For a new Cox Communications Cable Provider the remote control Model Number is URC-8820-MOTO and its remote control codes for Roku TV be 1756, 2360. For the DirecTV Cable Provider the particular remote control Model Number will be RC65 and its remote control codes for Roku TV be 11756, 10818. For a Dish Network Cable provider the handheld remote control Model Number is 21.1 IR/UHF and its remote control codes for Roku TV be 535, 556.
The ONN Cable Supplier the remote control Type Number is ONA12AV058 in addition to its remote control rules for Roku TV are 3851, 3201. Once the consumers remote controller are programmed with the respective codes then the user also have to activate their Roku accounts using enter Roku activate code to start out enjoying their preferred streams.
Hope you find your own appropriate code for your cable providers. For any help on adding the RCA Roku TV codes call our technical support staff members through toll-free numbers +1-855-804-1313 or visit them at roku.com/link
57helpful
2answers
Roku Customer Service Call 1-8O5-225-669O We are 24 Hour Available Call for Setup-Install-Fix Error.
Hi! I am roku product representative, You need to put the activation code from your roku to your roku account (if you have one) and just in case you don't have any roku account yet, you may create one or you may call a roku product representative 1-888-600-7658. thanks!
1helpful
How to hook up to roku
See this tip I have posted here on this site. >>> Setting Up A Roku <<< and read this, You want to try the Roku player so you can stream NetFlix to your TV over your home internet connection. It can be a bit of a hair pulling experience to set one up. So I'll try and make it as easy as it can be. First; Once you receive your player, and connect it to your TV. You need to get your new player on to your home network, be sure you have a router with wireless capability's. You will need to know the name of your home network, and you will need to know your WEB key or the pass key to secure your access into your home network. To do this, go to "Settings" (on the Roku menu) then scroll thru the menu until you see "Network", press network, look for your home network and press on it, then put in the WEB key to access your home network router. Remember after each step unplug the Roku for 10 to 20 seconds to set the memory.(may take more than 1 time with some players) NEXT; Go to Roku's internet site and set up your account with them, they will need info on how to bill you if need be. So they will need some bank account info Or you can use PayPal. They need this info in case you order a pay for movie or swap to a paid channel. Next On the Roku "My Account" page, down at the right bottom of the page you will see the "Link Player" button, follow this to receive your Link code, write this code down and go to your TV, Roku menu screen and put in the Link Code. This will now activate your new Roku player. Next you will want to go to NetFlix and set up an account with them. Same thing here, they need bank account info to bill you, if you stay past the free demo time limit. Now go back to your TV, Roku menu and scroll thru the menu to press on NetFlix, here you will go thru the Menu to get another link code. This time it will come on the TV, Roku menu to go back and put that code in your NetFlix account to activate your Roku player with NetFlix. Now in the process of all this you may have to unplug your Roku player after each link code to set it into memory. This causes a lot of folks trouble as they do not, "Turn Off" the Roku after they put in the network key, the Roku link code, then again after they put in the NetFlix link code. One last bit of help. Do not create a large Instant Queue on your NetFlix account. This causes problems with the memory usage in the Roku player, and It can keep NetFlix from loading.
1helpful
Trying to hook up roku wireless player, need pass word?
2answers
Can't fine roku.com to put in code to set up roku player ....
Roku Website.
I have posted a link to the Roku website above. Just click, and it will take you there.
Top Roku Televison & Video Experts
vince
Paul Carew
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
