Model issul2322 suppose to run 36 hours but stops about 10 minutes after in starts. When Ibshake it and get water in the base it starts working again then stops again
This issue is all electronic. The little computer has probably been contaminated with moisture. Unplug it, let it dry out a day or two and grab a few small tools and pop the front plate off. See if any of the metal receptors and wires have any corrosion or loose wires.
Grab some q tips and clean with rubbing alcohol. Let it fully dry out and reassemble. If you have any issues, it may be time for a new one
Perhaps your machine stops when it has reached the desired humidity level you selected. It doesn't have to be empty when it reaches that selected level. My mother thought the same thing but was so relieved to find out it was working properly all the time.
SOURCE: Fuel Gauge
I believe chevrolet has a recall on this problem having to do with wiring repair at the tank.
SOURCE: fuel guage 2001 chevrolet silverado 1500
Hi
We have the same truck that does the same thing.
The fuel sender in tank is faulty. It is in your gas tank. Common chevrolet problem.
SOURCE: Vehicle: 2000 Dodge Ram 1500, 5.9L, Automatic
the first suspect is the igniton switch. when this happens, take the ign key and just barlely turn it, either way, not enough to go off/on just a little tweak, it the lights come back on or flicker, that ign switch will need replacement.
SOURCE: Nissan Altima 1996 Engine stalls,it starts it only 2 hours later
is there any engine warning lights coming on if not when was the last full tune-up, plugs wires all filter's , if not or don't know ty that.
SOURCE: 94 golf iii starts to make a beeping sound after
Could be oil warning signal, check oil level, adjust to correct level.
