There are no user serviceable parts in this device. unplug it for 2 minutes- make sure the reservoir is filled with water, and the power is off- plug it in and turn thee power on- wait for the ready light to illuminate and try to use it.
good luck
https://www.6ya.com/mrmmike
SOURCE: Had nice steam when started, then no more steam.
Hi signashuff,
Sounds like you are on the right track. Since all seems to be working and you can hear gurgling, i.e. steam being made, then the the passages are plugged. The vinegar and water trick will clean the reservoir, but you still have to clean all the openings in the ironing surface. Have you done that?
Another vinegar trick to try is mixing hot water, vinegar and baking soda and pouring that into the iron while it is still frothing. Let the iron sit for 30 minutes on the soleplate with iron on steam. Then run some clear water through it and use it on a fabric you don't care about for the first session.
If that doesn't work, you might try a commercial cleaner such as CLR, Faultless Hot Iron Cleaner, Whink Steam Iron Cleaner, or Lime Away.
Distilled water is good to use in your iron but it still has minerals in it that will build up over time. It just takes longer to build up than tap water.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Keeps me working here. :>)
Thanks,
Handie Andie
SOURCE: NO STEAM COMES OUT: IT HASN'T
http://www.ehow.com/how_4899837_clean-shark-euro-pro-iron.html
This is the procedure for cleaning ..I guess if it do not produce any steam it has something blocking the steam ..(calcium deposits or such )
