No idea what model you have. check out the manufacture website
good luck
https://www.6ya.com/mrmmike
SOURCE: how do you change batteries
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
SOURCE: Stanley flashlight keeps blinking like a strobe light how can I fix it
I assume it is an LED flashlight (you did not say). Cheap Chinese-manufactured LEDs will flicker in this way when they go bad. The condition is not repairable... you will need to replace the flashlight. (Save the batteries.)
Each leg can hold three AA batteries. Simply unscrew a leg cap (foot) and drop in the batteries positive end first. My came with batteries in one leg only, but all of the legs hold batteries, so one can use 3, 6, or 9 batteries.
