SOURCE: opening top of cabinet
you have to use a putty knife. It is a pain in the neck. there are two clips where the top of the cabinet is there is a slot you can see the clip if you use a flashlight push theputty knife in and pull up. Then do the other side. They are directly in the frontt of the unit
SOURCE: Kenmore washer will agitate but not spin
You have a bad clutch/brake assembly.
It is attached to the transmission shaft. It takes a little work, but you could replace it yourself.
SOURCE: I have a Maytag top
This is a
common problem with a momentary power failure, the controller doesn't get time
to reset and return to an idle state before the machine gets power back and it
gets "confused". You will almost
certainly find that unplugging from the mains (Not just powering off on the
button, as some door locks have a sneak circuit, even when the power is turned
off at the button) and leaving the machine undisturbed for a full 20 minutes
will allow a reset, the door lock will disengage and all will be well when you
power back up.
SOURCE: I have a kenmore model 110 top load washer with
Make sure there is nothing down in hole where plunger goes to lock.
SOURCE: kenmore top load washer- have to bang lid several
FYI, I disconnected the lid switch and it still did same thing. Agitates somewhat but not full fledged with a clicking noise for a few minutes and quits. Thanks
