Microwave Ovens Logo
J
JACKIE l BOWMAN Posted on Mar 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microwave whirlpool model mh1160xs heating soup when it made a noise and stopped no power at all checked the line it has power .
Lawrence Oravetz
Level 3:
  • Whirlpool Master 10,558 Answers
  • Posted on Mar 02, 2019
Lawrence Oravetz
Whirlpool Master
Level 3:
Answers
10558
Questions
Helped
2697637
Points
29284
Take the cover off and check the fuses.
5 Related Answers
Anonymous
  • 883 Answers
  • Posted on Jun 08, 2007
SOURCE: kenmore 62622 (model) -microwave-loud noise -no heating
dis-assemble waveguide and clean thoroughly. try again. if no-go then failed magnetron. get new unit.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 28, 2007
SOURCE: Microwave ahs power but doesn't heat.
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 09, 2008
SOURCE: Whirlpool Gold Microwave Model GH7155XHS
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 06, 2008
SOURCE: Whirlpool Over the Range Microwave won't heat
Yes, I'm trying to help you. Sorry about all the questions, but it's part of diagnosis.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose or corroded connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron
- shorted high voltage diode
At this point, it seems pretty clear that the problem is in the high voltage section, most likely the magnetron, but possibly the high voltage diode or transformer..
Here are some links you or someone you know can use for test help to find the defective component, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
bestdarngood
Benjamin Patri
  • 3037 Answers
  • Posted on Jul 15, 2009
SOURCE: Microwave GE Model #JE1640WB - Makes noise when
Magnetron is done. This part heats the food. GE microwaves tend to have them stop working quite frequently. They basically make up the majority of the cost of the microwave, so instead of replacing the magnetron, you would be better off getting a new microwave.
Benjamin
Not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Our microwave has stopped heating. The lights and carousel work, but it will not heat. What can I do?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
The microwave is not heating
Basic
heatman101
My microwave is not heating but everything else works fine
Basic
heatman101
1helpful
When I type in the time to cook food, the microwave will run for about 2 seconds and then turn off and beeb 3 times. what causes that?
Boy, this sure sounds like a GE with a failing leaky magnetron, but that's not possible since you posted this under Whirlpool MH1160XS.
But it may still be a bad magnetron...
Whirlpool Model MH1160XZ miro hood combo - make rumbling noise
Sorry, meant to submit that as a solution.
2answers
Turning off turntable
If your model is MH1160XS, then no.
But if yours is a different model, you can download the owner's manual from the Owner Center here: http://whirlpool.com/custserv/index.jsp
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
