SOURCE: the Pandigital LCD Photo Frame's "frame extender" won't extend
Just pull it.... straight down. Too much torque may break it.
SOURCE: Pandigital Photo Frame - Slideshow leaves out Photos?
Size limit depends on exact model. Anything over 4GB will almost certainly not work consistently with any. model 1GB or less should work with any model. None of the images should be stored in folders, and all should be jpeg format (.jpg). If any of them have been edited, they may be saved as Progressive jpeg or something similar even if the extension (.jpg) remains the same. If you resave the missing photos in as JPEG in MS Paint, it should ensure they are compatible. You may have to format the memory card and re-add the photos to make sure it will work,
SOURCE: I have a Pandigital photo viewer (piece of ****)
Its probably because it may need a password or it is only for a usb not a usb cable
SOURCE: how do I transfer photos from camera to jessops 8 photo frame
make sure sd card is compatible with frame, ensure that the sd card has your photos on it and from there it should be plug and play
SOURCE: Pandigital 7" photo frame won't play avi files
I made my pandigital 8" touch screen videos work by:
used MOVAVI software to convert my .mov video to avi
then had a polarid mp3 player which had a simple software to convert to the polarid mp3's video files. large's video selection was 320x240.
that worked.
RA
