My pc has not long been formatted so there should not be any issues with it. Is this a software problem to do with the software I am trying to install?
Take a look at this. Should give you some idea of how it might have gone missing and how to get it back.
https://answers.microsoft.com/en-us/windows/forum/windows_xp/how-do-i-reinstall-rtl120bpl/a8d082ff-8d53-4a38-97e1-7fb3bab2a2d4
SOURCE: rtl100.bpl
This issue caused due to a start up item from spysweeper
you can remove that entry from registry.
Start - run - type regedit
it will open up registry editior go to the below location and remove the entry and restart the computer it should fix the problem
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
SOURCE: rtl100.bpl
If the error is that Rtl100.bpl is not found then you can try the following:
Go to start ,run, and type the following:
iexplore -extoff
And see it that stops the error.
If not, try repairing the system files by typing the following in the Run box:
sfc /scannow
SOURCE: DEVANT 2GB Device/Database Error.Connect to PC and Format as FAT!
Remobel disk free space 0 bytes
SOURCE: What is rtl120.bpl. A box appeared whenever I
The error could be connected to the advanced system care. Have you uninstalled any protective software lately?
It would seem that as the computer is starting it is trying to load a program that is either corrupt or missing, generally a program like reg cleaner or other utility program.
If its a case you have removed a program, try installing it and see if that works.
Get another copy of the advanced sys care program and reinstall that.
If this doesn't work, get back to me.
SOURCE: Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
