SOURCE: galant 95 backfires and shuts down at higher rpms
check ur plug wires they might be mismatched ...joe
SOURCE: 85 xr 600 wont start appears to have no spark had
yes buddy it the coil not making a strong enough spark say its only making 1000volts insead off 15000volts example hope this helped buddy
SOURCE: 94 yamaha vmax 600. How do you tighten the track??
you mean v max 1200? Losen rear wheel, align with a straight bar. Make sure the drive shaft spin freely
SOURCE: Yamaha TW 200 cuts out at high rpm
I have a tw200 and when I have this problem its from the cam chain slipping back a notch when I unload it from my truck. I leave it in gear so when I let off the cluch it acts as a brake. I ride by my self so thats why I load it that way. I am guessing you load and unload your tw the same way. So remove the timing cover and make sure you are tdc on both the upper and lower timing marks. The bike will run if the timming is off a bit. It's really easy to set the timing on these bikes. It's easier to look for how to on the xt 200 if you need more help.
SOURCE: 95 Yamaha vmax 600 (new belt is too tight)
sounds like the belt is wrong size. double check this,and if it is correct size make sure the secondary clutch is closing all the way.
I just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
Visit site:http://xurl.es/f1qg4
