Computers & Internet Logo
Ambre Brown Posted on Feb 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I used to be able to sign into cbs app thru my cable provider. This is no longer working and app is trying to make me purchase subscription. Is CBS no longer providing free access to cable subscribers
Level 3:
  • Computers & ... Master 19,187 Answers
  • Posted on Feb 27, 2019
Level 3:
Answers
19187
Questions
0
Helped
4344938
Points
82261
The CBS app is a streaming service and CBS now is charging cable providers for it. It is no longer free or available on some providers.
5 Related Answers
Anonymous
  • 301 Answers
  • Posted on Mar 31, 2008
SOURCE: Toshiba 50hm66 Sound problem on CBS channel only
check any SAP settings in the menu
Anonymous
  • Posted on Jul 28, 2008
SOURCE: i purchased a SANYO-DP46848 42"HDTV.
I just got the same exact one, when it searches automatically the first time it doesn't look for digital channels. go to Menu>manual channel search>cable. it will look for all possible signals and will take forever probably. the free digital channels will take several seconds to switch channel to channel, but they're there! They will show up on your screen as "DC 91-2" or similar. you can switch back to regular cable channels with the input button, you just cycle through all the inputs. hope that helps.
Anonymous
  • Posted on Jul 15, 2009
SOURCE: CBS station is gone. Only shows instructions for converter box.
I live outside the Kansas City Missouri area. I was having problems receiving one station. I decided to raise my outside attenna to get better reception. In doing so, I totally lost reception on another station. I only moved it up about 6'. I had to move the attenna back down to get that station perfect again. I still cann't get the station I'm missing but I found out that moving the attenna up/down or side to side can make a huge difference. I live about 50 miles from the stations I receive. Good Luck.
Anonymous
  • Posted on Aug 19, 2009
SOURCE: sciphone I68, service provider ATT, GPRS not subscribed
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to [email protected] (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to [email protected]
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Just be Patient and make sure you double check everything you put it it has to be exactly as it says.. I just set mines up yesterday and it works fine.. Hope this helps! It took me forever to find the solution hah
  • 6688 Answers
  • Posted on Jun 10, 2010
SOURCE: this tv is not connected to cable or dish, but has
How far away is the CBS station? Are there any obstacles that would block the signal (say new construction)?
What channels do antennaweb.org or tvfool.com suggest you will get from your location? (Antennaweb is more conservative and assumes an outdoor antenna.) Do you need to rotate your antenna to get one transmitter or the other? Indoor antennas are more likely to get interference and direction issues.
You may want to restore your TV to the default and then rescan the channels. (This may or may not help. It usually helps more with scrambled information than lost channels.)
I hope this helps.
(good luck. I've had issues with my CBS and Fox affiliates (sharing a transmitter location). At first it was clearly my TV and the reset helped. Now I have no clue as to the cause - the external TV antenna gives a strong signal on the other TV. The problem TV says the signal is bad and this is the closest transmitter and antennaweb says I should get it easily. Even pointing the antenna straight at the transmitter doesn't help.)
Testimonial: "to cindy wells, thank you so much. Your advise got my problem fixed. So grateful!!!"
I want to cancel my cbs all access please
You can cancel your subscription to CBS All Access at any time by contacting us at (888)274-5343, Monday to Sunday 8 am to midnight EST, or by logging into your account at https://www.cbs.com/all-access/account/ and clicking "cancel subscription."
Cancel cbs app subscription
Did you use iTunes to sign up?
Can you help me cancel my cbs all access subscription?
Nope.
That is strictly between you, CBS & your
Bank/Credit-Card Company
(they can help BUNCHES).
We are an all VOLUNTEER ... FREE service...
(loving to give advice...).
My advice is to avoid all subscriptions...
Prescriptions sometimes are quite useful
(vital for a few of us)...
Comcast was one of my worst subscriptions... Sadly it could only be cured by U-Verse
(also problematic ... about half the troubles
and HALF THE COST... In my humble opinion).
I obviously don't practice what I preach.
Carnac the Magnificent
IF I SUBSCRIBE TO CBS ALL ACCESS ON MY APPLETV, CAN I USE THAT SUBSCRIPTION ON MY AMAZON FIRETV?”
If the CBS app on your Apple TV requires a username and password then yes you will be able to use the same account on your Amazon Fire TV.
2answers
How do I cancel my cbs account it is automatically taken out every month
You would need to call them to do that we have no connection with CBS
Grand Canyon Tech
Grand Canyon Tech
