Firearms Logo
K
Kevin l Iocovozzi Posted on Feb 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Iver Johnson top break double action 38 with serial number 99116. What year was it manufactured?
raysaw
Level 2:
Sergeant:
  • Expert 267 Answers
  • Posted on Mar 14, 2019
raysaw
Expert
Level 2:
Sergeant:
Answers
267
Questions
Helped
96717
Points
732
You could contact the company here. They may have that information.
https://iverjohnsonarms.com/contact.html
1 Related Answer
Mister Danger
  • 5631 Answers
  • Posted on Apr 30, 2015
SOURCE: What year was an iver Johnson 38 cal. revolver serial number 36869 manufactured
My best advice: take it to a gun shop. They know all about guns
1helpful
16 gauge shotgun serial number A48381. When was it made.
Tell us what name is on the 16hgauge.
Mar 12, 2019 • Firearms
I have a Iver Johnson 22 caliber double action revolver, 8 shot cylinder, 2.75 in barrel. It’s a model 66. Serial number k12190. Can you give me information on this model.
You already have all the information model and serial number so what else are you looking for? A good source for numbers manufactured and dates is the Blue Book of Firearms Values. You can have any local gun dealer or gunsmith look this up for you.
Jan 17, 2019 • Firearms
What year was my Iver Johnson .38 centerfire 2 1/2 in barrel SS# 1684 made?
Try your question here.
https://www.thefirearmsforum.com/threads/iver-johnson-revolver-age-and-info.108514/
Oct 19, 2018 • Firearms
I have an Iver Johnson Cadet Model: 55S-A. 32 cal. 2 1/2 in BBL. 5 shots Serial No B27690. I would like to know more about the gun.
The Iver Johnson Cadet was offered as (the basic gun) as the Model 55 Target, and the 55A then the 55S Cadet and the 55S-A Cadet. The "parent" is discribed as: IVER JOHNSON MODEL 55 TARGET,Revolver,double-action,22LR,8-shot,4 1/2",6" bbls and 10 3/4"(6") 9 1/4"(4 1/2") over all length weight 24 oz.(4 1/2") 26os(6"); large frame,pull pin cylinder release with flash control front rim; recessed cylinder chambers;fixed sights,oversized molded one piece Tenite plastic target type grips; Does not have the "hammer the Hammer'action,matte blue finish; After 1958 cylinder is fluted hard chrome lined barrel introduced in 1955; dropped from production in 1979..the .38 caliber offering is designated as the Model 55S-A which is the same as the above except that: it was offered in .22LR,.32 S&W and .38 S&W(this is NOT a .38S&W Special) and as an 8-shot in .22, as a 5-shot in both .32 and .38. it is 7 1/2" oal w/ loading gate on the Right side AFter 1974/1975 this model is called"I J Cadet it was introduced in 1961 and dropped in 1979 Values: Vgood=$110..Good=$85 and Fair=$75. This data is from the Gun Digest Book of Modern Gun Values and more detailed Iver Johnson histroy can be had from www.gunshowbooks.com..check out Bill Goforth's Iver Johnson Arms&Cycle Works Firearms 1871-1993..Bill also frequents these forums and he along with Jim Hauff will likely correct any misinformation I may heve relayed as well as correct any ommisions.
Oct 04, 2018 • Firearms
I need to know hows to assemble iver johnson 38 american bulldog number stamped is 1616
Why don't you take it to a gunsmith? Unless you know what you are doing you could be missing some parts or put them in wrong and create a safety issue. It is well worth the money to have it checked out by a pro - and they can tell you if it is safe to shoot.
Apr 09, 2018 • Firearms
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 • Firearms
Walther pp s# 307421p What is year of manufacture?
Hope this helps..more ino if required..Cheers Pete Technical data:
Caliber: 7,65 mm und 9 mm kurz Function: Double-Action, Selbstladepistole mit Massenverriegelung Barrel length: 98 mm Weight: 685 g Magazine capacity: 8 Schuss Production data:
Company: Waffenfabrik Walther Location: Zella-Mehlis (Th?ringen) Period: 1940 - 1945 Amount: 84,000 Serial numbers: 165126P - 390653P
Apr 10, 2017 • Firearms
Iver Johnson pistal SS number 6551 top break
Yeah...what do you need to know? Not very specific.
Apr 07, 2017 • Firearms
Top Firearms Experts
vince
jws1013
Kolbrun...
Are you a Firearm Expert? Answer questions, earn points and help others
