SOURCE: Cleaning and descaling Krups Orchestro 889
take a descaler solution never mind vinegar not strong enought 1part solution 1part water put that in our water container start the machine open valve let it drip for a few second untill you see the solution leave it like that for 10 minute after open the valve and do it again untill emty after you emty the solution clean water container very good fill it with water open the valve rinse very good because that solution is very corosif enjoy cheers
SOURCE: krups orchestro 889 coffee maker,
Remove the the four screws at the rear of the machine you will need a pair of pliers to do this and remove the hinged lids on both sides.looking down from the top and to the front you will see a phillips screw on either side,remove these and the top will come off you will then see the channels that the coffee runs from the machine now just use a piece of suitable material to clean the pipe,easy!
