SOURCE: HP 7410xi small plastic piece in print cartridge carrier broken
If the spring did not damage the carriage flex I would suggest just using some epoxy to hold the spring properly in place. If the spring did damage the flex (as shown in this picture) then you might contact HP and enquire about an extended warranty for this issue. In the US call HP at 1-800-HPINVENt.
Regards,
Bob Headrick, MS MVP Printing/Imaging
SOURCE: can't get right side panel off on 3600n printer
You have to remove the formatter metal cage first by releasing black tabs then you can reach the snap tabs, be careful with on/off switch lever, Are you replacing cartridge locks?
SOURCE: hp 3600n getting error msg that cartridges not engaged
The problem is the locking arms on the right side of the machine are probably broken. HP has a tech bulletin out on this issue and they have a kit with updated parts to repair it. It is a very common problem.
SOURCE: x-spring tab broken in ink receptacle (HP officejet 7310)
I have the same problem, I can fix the wire in place, but there is a second problem, the wire poked a small hole through the thin plastic circuit membrain at the back, so even taping the wire in place no longer fixes the problem.
