Question about Texas Instruments TI-84 Plus Calculator
My TI-84 isn't showing my graph when i click graph how do i fix it
SOURCE:
  • 88 Answers
SOURCE: I can't graph on my ti-84 plus silv. edition
More than likely, you've put in a number in the xmin or xmax that is not correct. Example....you put in an xmin of 10 and an xmax of -10 which would be backwards. This could also happen in the ymin or y max.
The easiest way to fix this is to press zoom 6 which wil get you back to the default graph of xmin of -10, xmax of 10 and ymin of -10 and y max of 10.
If you can't see your graph on this screen and need to change the window, just be sure the number in the min for both x & y is smaller than the number in the max. You change your window size by pressing the window button.
Posted on Aug 15, 2009
  • 8081 Answers
SOURCE: I can't graph two functions at the same time
You bet I do, provided
1. there are no hardware problems I am not aware of;
2. that you are willing to follow my instructions.
First thing to do before any new type of problem
1. Turn StatPlots OFF : press [2nd][STATPLOT][4:PlotsOff] [ENTER]
Second thing: Clear the statistical lists
2. Press [2nd][0][PGRM] DownArrow to point to ClrAllLists.
3.Press [ENTER][ENTER]
Third thing : Configure the graph type to be FUNCTION graph
4. Press [MODE]. If FUNC (on fourth line) is highlighted. Press [Y=] and start entering the functions.
5. If FUNC is not highlighted, use Down arrow till 4th line, highlight FUNC and press [ENTER]. Press Press [Y=] and start entering the functions.
Fourth thing: Enter function and select them for graphing
1. As you start entering the function Y1=, notice that the = sign becomes highlighted. Press [ENTER] when Y1 is typed in. Make sure the = sign for Y1 remains highlighted as cursor moves to Y2=.
2. Keep entering the functions and verifying that their = signs remain highlighted as cursor moves to another equation.
3. When finished press [ENTER]
4. Look at the graph style for each function: it is a bit of line to the left of each Y. Here is a picture of all the 7 styles.
To set a graph style, highlight the style to the left of the Y, and press [ENTER]. Each time you press [ENTER] you see a new style, in the order shown on picture.
Avoid the style of Y6, it is bubble, and as such will burst and disappear once graph is finished. Avoid also the triangular ones (for Y3 and Y4) they will shade areas of the graph, and may hide other functions.
Fifth thing: Graph Functions.
1. You can press [GRAPH] to see your graphs.
2. If one curve is missing (and you have not set its style to be rhe bubble), it may be due to the Window dimensions.
Sixth Thing: Set Window dimensions and Zoom.
1. Press [ZOOM][6:ZStandard] to use standard window dimensions.
2. If curve still missing, Press [ZOOM][3:Zoom Out] to zoom out so that you may be able to see a bigger range for the functions.
3. If necessary press [WINDOW] and set the Xmin, Xmax, Ymin,Ymax to values of your own.
Dimensions must obey the conditions: Xmin < Xmax, and Ymin < Ymax.
Hope that helps.
5
Posted on Oct 29, 2009
  • 8081 Answers
SOURCE: My TI-84 Plus won't graph two functions at once.
Turn the satistical plots OFF
Press [2nd][Y=] (STATPLOT). Select or enter 4: to execute the command [PlotsOff] [ENTER]
Clear the lists (statistical lists)
Press [2nd][0] (Catalog]. Press [PGRM] C. The cursor jumps to the first command in catalog that starts with C (The greek letters in names do not matter). Scroll down a bit to reach the command [ClrAllLists]. Select it and press [ENTER].
Try your graphs again.
If you still have problems, just reset the RAM:
Press [2nd][+] (MEM). Press 7 to select [Reset] then [1:All Ram][2:Reset]. Press [Clear] to erase the Ram Cleard message.
Now you should be able to draw the graphs.
Hope it helps.
Thanks for using FixYa.
Posted on Nov 19, 2009
  • 102366 Answers
SOURCE: i want to graph a
You're trying to graph a function that does not involve stat plot features but the calculator probably thinks you are. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Oct 29, 2010
  • 102366 Answers
SOURCE: for my ti-84 I try to graph & it says
There is no one good window range for all graphs, since graphs can have different areas of interest.
Press the ZOOM key, then select ZStandard. This will restore the window settings to the default range, which will at least allow the graph to be displayed. You can then change the window range and/or zoom as desired.
If this doesn't do it, please reply to this post, giving the function(s) you're trying to graph and your current window settings.
Posted on Feb 15, 2011
My TI-84 will graph but it will not show me the table of values. It just shows up blank.
Enter the function using the Y= editor. Pressing [ 2nd ][Graph] (table) will display the table. You can then press [GRAPH] to see the grapg. If you want both graph and table side by side use the split screen feature.
To do so press [Mode]. Scroll down to the last line Full Horiz G-T. Highlight the option G-T. Press the Graph key.
Sep 24, 2013 | Texas Instruments TI-84 Plus Calculator
When i press graph on my ti-84 it only shows me the plot points and not the line?
At first, 2nd then stat plot. Then select plot option which you want to use. Press enter for On option and after that check plot type
Apr 04, 2013 | Texas Instruments TI-84 Plus Calculator
I have an TI-84 and when I put in my points in L1 and L2 I get my graph but when I go to my tables it doesn't show my points instead I get the X that shows up when there isn't points in.
when you do your regression (stat --> calc --> linReg/QuadReg/whichever regression you're doing)) make sure you put the equation into Y1 before going to the table.
Sep 14, 2011 | Texas Instruments TI-84 Plus Calculator
My TI-84 PLUS calculator wont show the graph after i type in an equation. please help!
You need to fix your graph so that it shows the correct y-axis and x-axis.
It works best if you press the zoom button and then scroll to find the ZoomFit option.
Then the graph should show up.
Jun 15, 2011 | Texas Instruments TI-84 Plus Calculator
When i click graph it says "ERR: INVALID DIM" i noticed under "y equal" mode that plot 1 and plot 2 are highlighted. how do i fix this, i need to be able to graph. TI-84 plus calc.
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Sep 06, 2010 | Texas Instruments TI-84 Plus Calculator
I can't select more than one function to graph It only will let me select one function
In order to select additional graphs, the Transformation Graphing Application will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family.
More information regarding this matter can be found in the Knowledge Base. The Knowledge Base can be accessed by clicking on the URL below:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=65121&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG14E1108A3A0CD3ABADCD67260B59BDE0CEEA20790F80F708D8A4FDACCD82D31F792BC1B01D2F67ECAE6718104B82CC1C8F
Apr 09, 2010 | Texas Instruments TI-84 Plus Silver...
TI 84 plus problem
Reset the calculator RAM and retry. Some old configuration settings are giving you the error.
Hope it helps.
Sep 28, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
56 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
