I found the manual for the Ryobi AP-10 planer here: http://attometer.com/pdf/20100424_Ryobi%20planer%20AP-10%20manual.pdf . I could download/save the file using Adobe Reader or the Chrome PDF extension.
I hope this helps.
SOURCE: Need a user manual for mastercraft thickness planer
I'd suggest calling 1-800-689-9928 and speaking with one of the customer service representatives
SOURCE: Need a Ryobi Model AP-10 wood planer owners manual
Here is a link to download the manual. Scroll down the page about half way and you'll see the Ryobi Manual download link. Hope this helps.
http://powertool.manualsonline.com/ex/thread/view/idThread/11678
SOURCE: Ryobi AP12 Thickness Planer---rubber feed rollers do not rotate
It is fixable if you are technically competent. All parts are still available online. It could be one of two problems:
1 - The rollers are driven by two gear & chain mechanisms on the height adjuster side of the unit. I did have a drive chain break once.
2 - If it isn't that than the gearbox has cracked / gear stripped under the torque load. This is also fixable, each individual gear and the gearbox housing are still available (10-09), but it requires substaintial teardown.
As you disassemble the unit just be careful once you remove the crossover height adjuster shaft - you don't want to turn one lifter by itself and have the planer higher on one side. It really is a simple teardown, just lots of parts. If you like the planer it is worth it; parts are cheap. If you are like me, you enjoy tearing stuff down to see how it's made and you hate throwing out $200 tools because only one little part broke!
SOURCE: I have AP-12 ryobi planer and it needs new feed
go to tool parts direct and order one
Testimonial: "Thank you "
