Hi Glenn,
Here is a link pertaining to your question.
I have also included a video link for the same.
Good luck,
JP
https://www.manualslib.com/manual/1070821/Lg-Wt1201c-Series.html?page=20#manual
https://youtu.be/IaTIbqolt_E
SOURCE: Brother Fax 2820
Brother Intellifax 2820 LCD screen has no display, all other things work fine.
SOURCE: lg wm2277hw
Is there power at the wall? if so open the panel and see that power it getting to the board? if so check for loose or broken wires, there may be a fuse in there. be careful when checking for power you dont want to get a zap.
Some component in pcb broken...
SOURCE: how does a PCB main assembly look like on a LG washing machine
pcb board main is the one thats accessed though the back of the washer behind the panel, the unit is usually at the bottom left side and has loads of wire and plus on it, it controls the motors and the heating element when told by the cyle board, it has switch-relays that turn things on at the times set for the setting you you to wash your items.
